I do. I'll give him a call and I also got a name in Tampa to try.
The new shop I emailed sent me a quote today of 2150 with 2 master install kits, or 1840 without the master install kits since I have a 14. And he said he would add the lockers for just the cost of the parts.
finally put on the Mopar bumper that I picked up cheap on Craigslist, took the tubes off and I'm thinking I'm going to bedline all of it, the back bumper should be going on this weekend hopefully
I also finally got the stubby Antenna X on, Vector UFOs, and new hood latches (Goodbye hood flutter). Also gave it a good bath and wax over the weekend.
Was at the Home Depot today and picked up everything I need to make myself a cart for my doors, going to finally get those off and be fully naked just in time for spring in MA.
Depends on your patience level and if you've soldered before. Took me about 20 min after verifying the voltage at the LED was 3.4 vdc. It's 12 vdc into the board at the wires but there's some resistors on the board already.
White and a few other color LED's run at 3.4, make sure you research before buying.
I'll be doing the rear view mirror map lights next. I may also test the two small lights that are on low power when headlights are on in the footwell as well.
