Old Mar 31, 2016 | 04:54 AM
  #46091
sa29560's Avatar
^^^^^. Can't wait to do this to mine!!!!
Front axle shortly as well, what wheels are those?
That is going to look super sweet!!!
Old Mar 31, 2016 | 05:07 AM
  #46092
larry0071's Avatar
LRG 106 is the model, they are available in different diameters as expected for the 5 on 5. I have the 18x9-5 on 5 with zero offset and 5" backspace. I'll be using a 1.5" spacer behind them.
Old Mar 31, 2016 | 05:22 AM
  #46093
missouri_sooner's Avatar
Originally Posted by Sclittle
315/70/17 Cooper MTPs with 17in Fuel Beast... Just waiting for the spare to arrive!
Looks good. Great choice!
Old Mar 31, 2016 | 05:46 AM
  #46094
sa29560's Avatar
That is going to look awesome, only as wide as it needs to be.
Great build, looks like you really do go a bit with the car care products!
Old Mar 31, 2016 | 06:05 AM
  #46095
larry0071's Avatar
I would guestimate that I stock around $2000 in chemicals for car care / detailing. It's a hobby passion. It shows even on my JK, I show up at the trail head looking like I just had a $1200 full correction done. Because I essentially do! I wheel about once a month, the 3 weekends are spent cleaning, buffing, painting, coating, dressing, sealing..... my other passion! I start at the bottom and make the frame, brackets, engine, axles and all look new. Then I go up and get the paint back, then I spend a day or 2 inside. Once you can't tell it's been off road (aside from bent steel under it!).... it's about time to take it back into the rocks and start again!
Old Mar 31, 2016 | 06:09 AM
  #46096
Dontfollowmeyoullgetstuck's Avatar
Installed
PS front brawler bumper, warn m8000s PS AEV carrier rear bumper, trimmed flares and 37s on black pintlers.
2011 JKU 17" Pacers 295/70/17 mastercraft courser MXT Gibson dual exhaust rubi shocks rubi 10a springs 2.5" RC series II lift
Old Mar 31, 2016 | 06:21 AM
  #46097
larry0071's Avatar
Originally Posted by Dontfollowmeyoullgetstuck
Attachment 642340
Installed
How much total lift is that:
Suspension = ?
Body = ?
I see you saying 10th Anniversary Rubicon shocks and springs, but then you say after that that there is a 2.5" Rough Country Series II lift. I am asking because I also have a 2 door and I am picking up 37"x13.5 tires this weekend.
You also say (and they look like!) you have 37" tires, then you say a bit lower that you have 295/70/17 tires.
If you have the 295/70/17, you would have approximately a 33.25" tall by 11.6" wide tire.
You have me so confused! Or... am I looking at an out of date signature line and I am confusing it with the upper line sayng what is actually in the photo?
I wanted to here what rear bump extension your running and how dramatic the cutting was on the rear most pinch seam. I'm about to travel down that same road. I hope my Willys looks like yours. That's a big and bad look!
Old Mar 31, 2016 | 06:30 AM
  #46098
Sclittle's Avatar
When can I drop mine off?
Old Mar 31, 2016 | 07:17 AM
  #46099
MikeNacJK's Avatar
Relocated the evap canister on my JK above the rear axle!
Installed a front bumper, rear bumper an tire carrier on a customers JK!
Old Mar 31, 2016 | 07:55 AM
  #46100
Stephane87's Avatar
Originally Posted by MikeNacJK
Relocated the evap canister on my JK above the rear axle! Installed a front bumper, rear bumper an tire carrier on a customers JK!
What front bumper is that?
