2012 JK Brake Question
Old Mar 10, 2012 | 04:15 PM
TrainerJuice's Avatar
Default 2012 JK Brake Question
I got my 2012 JKUS in Aug 2011. I have 5000 miles on it. Whenever I reverse my brakes squeek and make whiney noise. Is this normal? Should I do something about it?
Old Mar 10, 2012 | 05:28 PM
eslack32's Avatar
How often do you use your E brake?
Old Mar 10, 2012 | 11:18 PM
Never. I don't even off road yet
Old Mar 11, 2012 | 12:51 AM
rooster1976's Avatar
Mine do same.......when I depress brake and put in reverse it squeals until I let off brake completely.
Old Mar 11, 2012 | 02:29 PM
RubiconJim's Avatar
Mine does the same thing and has done it since day one.
Old Mar 11, 2012 | 03:37 PM
rbye05's Avatar
my brand new jku does it
Old Mar 11, 2012 | 03:47 PM
I guess it's normal then thanks peeps!
Old Mar 11, 2012 | 04:38 PM
eslack32's Avatar
Try using your e brake once in awhile. I believe it helps to adjust them.
Old Mar 12, 2012 | 03:41 AM
smittycm's Avatar
Veteran: Marine Corp
I use my e-brake every time I park. Haven't heard any noises when reversing yet. I only have about 300 miles on my 12 so far though. I wouldn't say the noise is normal necessarily.
Old Mar 12, 2012 | 10:35 AM
AJMBLAZER's Avatar
Anybody know what material the brake pad's material is?
I had a Suzuki Grand Vitara several years back that had organic pads from new. They were horrible. Dusted bad and were practically sponges they absorbed so much moisture. Squealed if you nailed it hard, used in reverse, if it was at all wet out they had this horrible DROOOOAAAAAAAAAAAAANNNNNN, end of each braking incident was a droan...
...all went away by switching to mid range semi-metallics.
