35" tires
Old 09-10-2014, 03:25 PM
Davorama's Avatar
Default 35" tires
Looking through my weekly catalogs it seems most 35" tires are made for 17" rims. Is seems like you could save a lot of money to go from my stock 17"s to 16" since I intend to get new rims anyway. Has anyone done this?
Old 09-10-2014, 03:38 PM
Tooadvanced's Avatar
Ppl do and ppl go to 15s although you need to be careful which 15 u pic do to brake caliper clearance. But as u said most manufacturers are going to 17's and doing away with producing tires for 16s and 15s
Old 09-10-2014, 04:34 PM
Mark Doiron's Avatar
Many of us run 35s on 16s. If you plan on upgrading the tie rod, it gets so close it affects wheel balance weight placement. And I doubt a big brake kit would fit.
Old 09-10-2014, 04:47 PM
Davorama's Avatar
Thanks it looked that way but never hurts to get other opinions. So the break calipers shouldn't have problems with 16"? Thanks again
Old 09-10-2014, 04:49 PM
Davorama's Avatar
Many of us run 35s on 16s. If you plan on upgrading the tie rod, it gets so close it affects wheel balance weight placement. And I doubt a big brake kit would fit. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=575183"/>
Got it. Thanks
Old 09-10-2014, 05:10 PM
darkknight1999's Avatar
I have 35's and 16" wheels...
Sent from my NSA monitoring device... Using the JK-Forum app
ID:	575187   Click image for larger version
Old 09-10-2014, 05:12 PM
Davorama's Avatar
Originally Posted by darkknight1999
I have 35's and 16" wheels... Sent from my NSA monitoring device... Using the JK-Forum app
Nice!
Old 09-11-2014, 12:28 AM
... So the break calipers shouldn't have problems with 16"? ...
Never heard of anyone who had problems with OEM brake calipers and 16" wheels. A few folks have had to be choosy and/or grind a little on the caliper to fit 15" wheels, though.
Old 09-13-2014, 12:39 AM
AirForceMike's Avatar
I ran 16" wheels with 315/75R16's for a few years, never had any issues. I like the way a beefy sidewall looks anyways, I've never been a fan of big rims.
Old 09-13-2014, 01:00 AM
kjeeper10's Avatar
16's work but tire load range is limited to D/E
I would not run a 16" again .. Go 17's for more options in sizes/load range c
2007 Rubicon /2 door/6 speed
Quick Reply: 35" tires
