4 wheel drive knob removal?
I've got an 08 and it just presses on. It took me a while but the best way I found was to get a wrench slightly larger than the shifter rod, wrap a rag around the wrench to protect the knob, put it onto the rod right under the knob then beat the wrench from the bottom with a hammer! I couldn't believe how tight that knob grabs on!!!
if you put it in 4low and sit on your center console and pull and jiggle it at the same time it will come off just make sure you keep your mouth closed cause you might lose some teeth when it finally lets go
