Anyone remove Soft Top completely instead of just down?
#42
I have recently got a soft top for my JK and am missing the torx screws to attach the soft top frame to the Jeep. Does anyone know what size I could use or should I get the quick discos?
I do not anticipate removing the entire soft during the summer months...but it will be folded down all the time! Any pics that someone can provide to help me figure what I need would be great.
Thanks!
Thanks!
Sandy
#43
You will find out quickly what you like. Dont waste money on quick disconnects. It takes zero time to take them off with a torx. I like it with no option to have the top on sometimes, it adds adventure. Sometimes I need to have an option and want to be able to be warm. You'll find your rhythm.
-Ram
-Ram
#44
OK, so I read threw 5 pages and let me see if I have this correct. All I have to do to remove the soft top is remove 4 torque screws holding the frame to the roll bar and the whole soft top will remove? Why I ask is I want to remove the soft top completly and put on a hard top. Is there anything else I need to do. I am trading my soft top for a hard top.
#45
#47
The brackets are just help in by screws? Are they the black frames I see on top of the doors? Once all that is removed the hard top will just sit in place?
The hard top will need these "pucks" that allow you to screw the top down to the body of the jeep both of my jeeps came with hard tops so I am not sure if a soft top only jeep comes with those. Other than that that's pretty much all there is to it. You can verify if you have the hard top screw pucks just go take a look at the cargo area of your jeep. If you have screw threads in the holes that run along the top lip of the cargo area then you are good to go.
#48
OK, I just looked. I have holes that run along the cargo area on each side, there are no threads in the holes just a hole about 4-5 on each side. Also where the roll bar is on top I have holes where the 2 big plastic type finger screws hold on the front of the freedom top.
#49
Ok. So you need those pucks I am talking about. They will allow you to attach the top to the jeep. You will want to get these from the person you are getting the hard top from. I think my four door had three pucks on each side and my two door had two pucks on each side. I didn't drive either jeep today so I can't take a pic for you.
