Anyone see a noticable difference using drop in filters?
Old 04-20-2010, 03:42 PM
Ronstar83's Avatar
Default Anyone see a noticable difference using drop in filters?
I just used the Superchips Flashpaq and had unbelievable results. I tuned it to the correct tire size and programmed it to performance 93 octane after filling it with premium gas. For the last year I have been averaging 13.2 MPG combined. This last few days driving the same routes I am currently averaging 19.3 MPS's. Speechless. I was looking into intakes but decides against cold air because I remember what my engine looked like the last time I went and played in the mud. That said, I am curious if anyone has had luck with the drop-in filters and if so what brands work the best?
Old 04-20-2010, 05:22 PM
JK-Tex's Avatar
I've got a K&N drop-in. Makes it sound *slightly* less breathless in the top end, but no real difference. Besides, it's not like you should be revving the 3.8 above 4,000 rpm, anyway. Might void your warranty!
Old 04-20-2010, 05:27 PM
PoorDad's Avatar
Default No noticeable difference
I did not really notice much of a difference between the stock air filter and my AFE dry drop in one. The thing I liked about the AFE , and the reason I got it, was that is reusable and does not require oil. You can take the filter out on the trail, bang it on a rock and be back up to 80% filtration. The AFE filter itself drops down deeper than the stock one or the K&N, allegedly letting more air in
Old 04-21-2010, 06:28 AM
myklt8's Avatar
I like my AFE for the same reasons, I don't think you'll see any gains from a drop in. even if they do flow more air, you are not going to be running high RPMs constantly to take advantage of the higher flow
Old 04-21-2010, 06:40 AM
zzx81's Avatar
I put in a drop in K&N filter at about 18,500 miles about a year after I bought the Jeep. I did have a noticeable difference in low end power after I had replaced it. There is a hill on my daily commute that I was unable to maintain 40-45 mph or even gain speed in sixth as I traveled up it. After replacing the filter, I have had no problem maintaining speed on this hill.
For the 18,229 miles that I recorded before using the K&N filter, I was getting an average of 15.531 mpg. In the 13,302 miles since I have replaced the filter, I have averaged 16.549 mpg. My daily commute has not changed in this time. I have been driving with the filter in for just over a year now.
I have a stock Rubicon Unlimited with a six speed and soft top. Most of my driving has been in Dallas traffic.
I hope this helps some people that are wondering about what gains you receive from just adding the K&N filter, and sorry for all the numbers.
Old 04-21-2010, 09:26 AM
iggy's Avatar
x2 I didn't notice anything either when i installed my AFE dry drop in filter. I really got it for the same reason no more buying filters and no oiling. As far as filters go it's one of the better ideas, I've have K&N before and they work well but i like the idea of no oil.
Old 04-21-2010, 01:29 PM
CDavisJK's Avatar
I replaced my stock one with a K&N drop it. The old one was really dusty. But even then I didn't notice any difference.
Old 04-21-2010, 01:33 PM
RubiZealot's Avatar
Do you think this is just because of a new filter or that it was a K&N?
Old 04-21-2010, 01:43 PM
zzx81's Avatar
Looking at my mileage log, I would say that the MPG gain is directly due to replacing a stock filter with the K&N. My mileage was fairly consistent before I replaced the filter, and the stock filter was not very dirty when I took it out after 18,500 miles.
I would also attribute my experience with the hill on my normal commute to having a K&N filter. It is not a huge difference, and if I had not driven the same route day in and out, I probably would never have noticed any power difference between stock and the K&N.
I don't think that there are any earth shattering gains to be had, but the extra 1 mpg and not having to down shift at lower RPMs has made it worth it for me.
Old 04-21-2010, 01:55 PM
RubiZealot's Avatar
given the price, this seems like a worthwhile mod. 1 MPG is big money over a year.
Quick Reply: Anyone see a noticable difference using drop in filters?
