Bad Day with JK
Old 02-15-2010, 03:09 PM
BLK-JK23's Avatar
My jeeps at the dealer too :(
new trans... clutch and flywheel.......
@ 3000 miles.......
never buy a jk on a monday or a friday
Old 02-15-2010, 03:33 PM
BlackNorthernJK's Avatar
Originally Posted by saltman
33" is hardly anything that would cause the damage he has. that's a stretch.
and the axles are a little stronger.... but the JKs wider and heavier. balances out. I wouldn't think of them as being stronger than previous models. If anything, I've seen more broken Us, bent tubes, and all kinds of poorly welded brackets shearing on the JKs that didn't happen before.
Glad to see you were warrantied without a fight. If anything water in the dif, would have been a flag at most places. not the 33s.
that's besides the point, what I'm pointing out is that they are aftermarket larger (yes even just slightly) tires and the dealership has every right to say no because of this, whether I agree with it or not
agreed the JK's are wider and heavier, I'll say that yes that should about equal out....
Old 02-15-2010, 05:23 PM
rripror's Avatar
...hey blk-jk23, i've got a 2010 2-dr, 6-spd on it's way. could you expand on what happened and how it was dealt with by your dealer?
Old 02-15-2010, 05:27 PM
JPSquad's Avatar
You may also want to extend your axle breather tubes.
http://project-jk.com/jeep-jk-write-...hose-extension
Old 02-15-2010, 05:32 PM
phljeeper's Avatar
@ 3000 miles.......
Interesting, I just had an issue with my clutch at 6k. They are ordering parts to replace the clutch under warranty. I thought I had a belt loose, it was squealing with the clutch out and quiet when I pressed the clutch. They said it needed to be replaced. Seems strange with such low mileage.
Quick Reply: Bad Day with JK
