Blowing engines due to oil weight?
Old Sep 15, 2010 | 01:14 PM
20JK10's Avatar
Default Blowing engines due to oil weight?
I'm sure we've all read a story of the blown engine at 40k. I wonder if it could be due to the weight of the engine oil [5w-20]? I was curious as to what the Caravan engine uses, so I downloaded the owners manual from the Dodge website. The 3.3 and 3.8 are the same at 5w-20 and the 4.0 uses 10w-30. I wonder why there is a difference of oil between 0.2 liters engine size?
Old Sep 15, 2010 | 01:21 PM
angermgmt's Avatar
Well if the engineers have their stuff together, its due to the engines tolerances, clearan ce specs etc...
Old Sep 15, 2010 | 02:03 PM
JK-Tex's Avatar
I'd have a hard time believing that this is happening because Jeep moved to a thinner oil.
Old Sep 15, 2010 | 02:08 PM
NorthRiver's Avatar
Exactly.
People are really living in the past when it comes to engine oil.
Old Sep 15, 2010 | 02:24 PM
birdiecat's Avatar
maybe the cranks are coming out of these engines because of the steep angles that we submit our jeeps to. it only take a split second with out oil being supplied to the crankshaft to pull a rod or main bearing.
Old Sep 15, 2010 | 03:55 PM
Rednroll's Avatar
3 Words from me as far as I'm concerned....."Lifetime Powertrain Warranty". Oil changed every 3000 miles, and saving all my receipts.....Let her blow.
Old Sep 16, 2010 | 07:49 AM
Rawb77's Avatar
I get my oil changed at the dealership, they keep a record of all the service work I've had done on my Jeep.
And because I still dont trust them to keep accurate records...I keep my receipts.
Old Sep 16, 2010 | 08:03 AM
Pluke the 2's Avatar
I want to see some evidence to someone blowing their engine and Chrysler warrantying the work per their "Lifetime Powertrain Warranty".
(Of course I wish nobody blows their engine)
Old Sep 16, 2010 | 09:33 AM
sixty5vdub's Avatar
x2 Unfortunately I bought my Jeep used, plus I was 9k miles over the 3yr/36,000 mile warranty. I think I have heard of one person getting them to cover a partial on the replacement. Not sure if they had LPW or not.
But from what I have heard, Chrysler/Jeep responds the same to pretty much everyone who has tried to get their engines covered: You are SOL.
I hope none of you Jeepers out there with the LPW have to find out the hard way that they will find ANY reason they can to not cover things. Hence all of the threads online from people who don't get ball joints, axles, evap canisters, etc. replaced under warranty because they modded their Jeeps. Even if the mod had nothing to do with the failure of the part.
If the dealer does all of the maintainance on your ride, or if you have all of the receipts for everything, I hope the works out for you, if the time ever comes. Hopefully it won't.
Sorry, but I have zero faith in Chrysler/Jeep's customer service.
Anthony
