Bolt Property/Class
Old Oct 30, 2009 | 11:28 AM
txtrav's Avatar
Default Bolt Property/Class
Gents - How do you determine if a bolt is a class 8.8, 10.9, etc.? I'm installing a lift tomorrow and want to ensure I torque to the proper settings (i.e. a 12MM bolt is torqued to 55ft/lbs if it's class 8.8, but 75ft/lbs if it's a 10.9).
Thanks!
Old Oct 30, 2009 | 11:37 AM
RedneckJeep's Avatar
See if this will help.
http://www.americanfastener.com/technical/grade_markings_steel.asp
Old Oct 30, 2009 | 11:39 AM
Smelt_1's Avatar
Unfortunately, if the bolts were made in China then it will not really matter. I'd go on the low side if I were you, before they start snapping. But to answer your question, the code should be on the head, and very clearly read. Otherwise it is a fake.
Old Oct 30, 2009 | 11:59 AM
Ryanc's Avatar
Yup
Old Oct 30, 2009 | 01:24 PM
Gcollura's Avatar
Follow this write up for torque settings and you should be good.
http://project-jk.com/wp-gallery2.php?g2_itemId=117479
Old Oct 30, 2009 | 02:08 PM
txtrav's Avatar
Much appreciated insight, guys - just what I was looking for. Plus, that torque-setting write-up is the cat's pajamas!
Old Oct 31, 2009 | 03:56 AM
TINMAN080's Avatar
This cat don't wear no jamies...
Name:	halloween 2009 001.jpg
