Can someone tell me what this means?
Old Aug 3, 2014 | 03:44 AM
jessjones92's Avatar
Default Can someone tell me what this means?
Old Aug 3, 2014 | 03:46 AM
Mountain Man Tim's Avatar
the jeep with the squigly tread marks is your traction control. its too blurry for me to read the other one.
Old Aug 3, 2014 | 04:23 AM
red09's Avatar
ESP=Electronic Stability Program (control)
BAS=Brake Assist System
Now, what are the conditions to which those lights are on? They normally come on if you are in 4lo as these safety features are disengaged.
Old Aug 3, 2014 | 05:55 AM
myrojk's Avatar
They come on when your hubs are going bad and when your steering wheel isn't center
sent from the bottom of a water hold and didnt lock the motor
Old Aug 3, 2014 | 08:24 AM
Mark Doiron's Avatar
Or a wheel sensor is going bad, or the wiring to one has been damaged, or when you've got a battery going out. I've seen all five of those scenarios. And the lights are not consistent. Sometimes it will be more or fewer lights that go off.
Old Aug 3, 2014 | 08:26 AM
Waldo_88's Avatar
Mine also came on when my clock spring went bad..
Old Aug 3, 2014 | 09:07 AM
Tomssw's Avatar
There is a fix for misalign ed wheel, start jeep, turn wheel full left and then right then center. Shut off, start again then drive straight for 50' or so. See if light goes out after some driving.
Old Aug 3, 2014 | 09:09 AM
Tomssw's Avatar
It worked for me when esp and antilocks acted up after upgrading tires
Old Aug 3, 2014 | 03:29 PM
red09's Avatar
To continue my smartazz thread... if you are driving straight down the road and your steering wheel is crooked enough this light will come on, the work "JEEP" is canted to on side type crooked. To fix this, in most cases, you need to adjust your drag link see link:
Project-JK.com - Jeep JK Wrangler Resource » Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
With the front wheels pointed straight, loosen the two 15mm bolts and turn that turnbuckle until JEEP is straight and level. Re-tighten the bolts and I mean crank on them. then do what Tomssw suggests. Some times you have to drive a couple of miles to get the lights to go off. 10min fix not counting drive time.
