cb antenna cable
I ordered a cb and Firestick. I connected the cable to the antenna and routed it to the front of the vehicle. The end that connects to the cb control box is just a wire and I have the connector seperate. How do I put the end on to plug it in. I'm sure it didnt come pre installed that way the wire was easier to run. Thanks .
Originally Posted by NJ-RUBICON
Your cable is messed up then. The coax should be the same on both sides. Plug and play. One end goes to the antenna mount the other right in the cb. No extra bits and pieces
This is what I should look like. I say go get a new coax. Or figure out how to build yours
And I was able to fit it by cutting the rubber stopper thing. And fit the ground as well through the same hole. Jut have to cut it
