cleaning black plastic
Old 09-27-2011, 02:15 PM
big c's Avatar
Default cleaning black plastic
How to clean peanut butter stains off black plastic
Old 09-27-2011, 02:25 PM
BKGM Jeepers's Avatar
I assume this is a question.
Penut butter leaves an oily residue. That is what you are probably seeing. You should be able to armor all it and saturate the rest of the plastic so it looks the same. Or, you could use a solvent to try and remove the oil and then treat the plastic to avoid discoloration.
I've heard very hot water would also work if you are working on exterior stuff.
Hope this helps!
Old 09-27-2011, 02:28 PM
Jknockers's Avatar
I would use some sort of interior/exterior cleaner for plastic that kinda leaves a sheen. Soke the rag good and turn the rag often.
Old 09-27-2011, 02:29 PM
dogsonparade's Avatar
Dawn soap.
Old 09-27-2011, 03:30 PM
19Delta's Avatar
Let your dog lick it...
Old 09-27-2011, 05:39 PM
big c's Avatar
Lol that should work ha
Old 09-27-2011, 05:42 PM
mike-d's Avatar
I just use that good old armoral. get the original spray bottle and a rang, cleans shines and doesnt attract a lot of dust like you would think. I think its the best thing I have tried and I have tried everything.
Old 09-27-2011, 06:37 PM
Anaya's Avatar
Tire wet works good makes it look new.
Old 09-27-2011, 06:52 PM
DarthJeep1's Avatar
Originally Posted by dogsonparade
Dawn soap.
X2 dawn will remove help break up the oil.
Old 09-27-2011, 06:59 PM
duluthjk's Avatar
Cover the rest of the plastic with peanut butter too so you even out the stain.
Armor All it. I do all the plastic on the outside of my Jeep just to keep the Iron Range Orange dirt from staining the plastic.
Quick Reply: cleaning black plastic
