Clicking from Rear when Accelerating from Stop
I was wondering if anyone knows what may cause a click sound when accelerating forum a stop? It appear to come form the rear (possibly control arms?). I added a Teraflex 2.5" budget boost and have re-tightened all of the bolts at the upper and lower control arms, the track bar and sway bar links. Before putting back on the lift and pulling everything apart, I thou I would start here. Any thoughts or ideas of what to looks for would help. The noise started about 1,000 mi after the initial install. I have also noticed some "creaking" sounds when accelerating/decelerating. When I have attempted to flex the suspension or to bounce on the side rails or bumper to create suspension movement, no sounds. Confused?
Hi Friend
I'm having the same problem, I have 2 1/2'' boost lift 33.75" tires and 4.88 gear, the clicking noise starter right after 100 miles. Did you find out your problem ? It looks like we have the same problem.
Thank you
Thank you
