cost for diff fluid change???
Old Mar 1, 2010 | 06:32 PM
rome07JK's Avatar
Default cost for diff fluid change???
the dealer wants to charge $500 to change my diff fluid and told me diff fluid costs like $200??? are they for real or is this some kinda BS? i google diff fluid and it was $20 a quart? should i just go somewhere else?
Old Mar 1, 2010 | 06:40 PM
JKOperator's Avatar
Default Wtf?
Yes. Here: https://www.jk-forum.com/forums/show...t=differential
Old Mar 1, 2010 | 06:41 PM
jmat1980's Avatar
Do it YOURSELF!!!
It is so easy its rediculous...remove bolts, drain fluid, spray gears with break parts cleaner, re-do gasket or use lube locker, replace cover/bolts and fill. Use 2 qt front and 1 qt rear Synthetic. Total cost=under $100. VERY easy. There is even a write up here
http://project-jk.com/jeep-jk-write-...r-installation
Old Mar 1, 2010 | 06:42 PM
jmat1980's Avatar
Or bring to to me and ill do the whole job for only $399
Old Mar 1, 2010 | 06:46 PM
thom1879's Avatar
Hahaha, it takes about 30 minutes! That works out to $800/hr in labor! I'd like to see the people on this forum that always complain when dealership are called stealership defend this charge.
Old Mar 1, 2010 | 07:02 PM
john smack's Avatar
I had my front axle shafts replaced under warranty and my local dealership doesnt cover maintainable fluids under warranty work they charged me 60 bucks for the fluid they used... I laughed at the guy then he told me he was serious
Old Mar 1, 2010 | 07:07 PM
JamesJKB's Avatar
I did this myself, it is super easy. Don't pay someone else for this. It is easier than a regular oil change.
Old Mar 1, 2010 | 07:18 PM
sm_rubi's Avatar
That cost is insane...it's one of the easier maintenance things you can do. Even if you go with Royal Purple and buy things like a drain pan and long funnel you'd still spend less than $100 by DIY!
Old Mar 1, 2010 | 07:28 PM
JKOperator's Avatar
Wow. I had a front axle seal replaced under warranty. Seal, gear oil and RTV were all listed under warranty in the "Amount" column of the R/O. I asked if they replaced both seals, they told me no. I smiled and said see you when the other seal fails.
Old Mar 1, 2010 | 07:31 PM
jmat1980's Avatar
Thats BS, the Warrantied problem caused the fluid to need to be replace.
