Death Wobble
Old Dec 24, 2008 | 06:36 AM
Jeepetto's Avatar
Default Death Wobble
I have read a few stories about the DW and I wasnt sure what anyone was talking about until the other day when i was going about 50mph and ran over a set of train tracks and thought the jeep was going to fall apart, after i came to a stop the jeep acted normal. I drove to a jeep dealership that was 2 miles down the road and told the service guy and he said he would have a tech look at the wheels and said that everything is fine. 2 questions
1. Is there any particular area i should look under the jeep to see if there is damage
2. Would this be covered under warranty, I bought the jeep 5 months ago and have not done any mods yet?
Old Dec 24, 2008 | 08:06 AM
jkxtx's Avatar
Check your track bar. It's probably either loose or the mounts are broken.
Old Dec 24, 2008 | 08:26 AM
wayoflife's Avatar
JK-Forum Founder
please give us some specs on your jeep. what kind of mods do you have on it if any. as mentioned, DW is almost always a problem associated with your track bar. either the mounts are failing, bushings are worn or the bolts are not tightend to spec.
also, do a search in the modified forum as there are TONS of threads regarding DW. here is one of the most recent ones:
https://www.jk-forum.com/forums/show...t=death+wobble
Old Dec 24, 2008 | 08:32 AM
wetworx's Avatar
Sorry to hear about your DW. I had one on my lifted 95 GMC 2500. In my case it ended up being a bad Pitman arm (of course it was one of the last things we looked at).
Do a search of this forum...there are tons of good theories and fixes on the subject.
Good luck.
Old Feb 3, 2009 | 07:18 PM
sahara1's Avatar
my wifes 05 rubicon did the same things.......found out that one of the front wheels lost a weight used for balancing the wheel. also, the dealer blamed the dw on low tire tread and low tire pressure....
Old Feb 3, 2009 | 07:21 PM
sully151's Avatar
He is bone stock, so I would assume it would be covered by warranty.
