Did I make a mistake
Old Jun 11, 2015 | 05:50 AM
gdp0341's Avatar
Default Did I make a mistake
So I've always wanted a jeep and finally was able to purchase a Jeep Wrangler Sport with the 3.8 engine. Here is my question should I start building it up or should I just upgrade to a Rubicon in a year or so and then start to build it up. Right know I'm thinking of a 2.5-3.5" suspension lift and 33 or 35" tires. I would like to do some off roading nothing major. Money is an issue do to wife kids house dogs cats and life.
Old Jun 11, 2015 | 06:09 AM
BillyJack's Avatar
Build it. You have a great platform to start with.
Old Jun 11, 2015 | 06:24 AM
ACJK22's Avatar
Build it up and customize to your liking. Had the same thoughts but then started upgrading and realized I would have done the same with a Rubicon
Old Jun 11, 2015 | 08:22 AM
jkforum96's Avatar
Build the Sport if you are happy with the creature comforts. The only real advantage a Rubi would give you is lockers.
Old Jun 11, 2015 | 09:09 AM
AirJordan613's Avatar
I thought the same thing after I started wheeling my Sahara that saw only pavement for the first 3 years of ownership. I slowly built it up, and it now has 4.88 gears, eaton e-lockers and a manually disconnecting sway bar, 3.5 AEV lift, wheels, 35" tires, etc. Far more capable than a stock rubicon now, and on par with a rubicon of the same size lift and tires. Would the rubicon have been a little cheaper at the end of the day? A little, yes. But with my budget at the time, I got what I wanted and over time it became what I wanted it to become. It's 5 years in the making now, and it's taken 5 years to make mine this way. No need to rush yours. And it's a 3.8 which when properly geared has performed just fine for me. Hope that makes you feel good about your purchase. Enjoy it
Old Jun 11, 2015 | 12:17 PM
gdp0341's Avatar
Thanks for the god info guys
Old Jun 11, 2015 | 12:34 PM
Chitownpete's Avatar
It seems like lots of Rubicon owners wind up dumping a bunch of cash just like everyone else. Not sure as I'm new to this but I'm just saying what I've seen.
Old Jun 12, 2015 | 11:34 AM
Mark Doiron's Avatar
You can have a ton of fun in a non-Rubicon JK. I follow, and have follow me, Rubicons all over the country. Check out my videos in YouTube DigitalByDoiron.
https://youtu.be/0Yq51rHh8MY
Old Jun 12, 2015 | 11:57 AM
robsjeep9's Avatar
JK-Forum Ambassador
Meh the rubicon lockers break all the time .... Build it like I did my 09 X model.... One step at a time as money allows and in the meantime enjoy what you have it's quite capable.... Easy on the Dana 30 tho ......
ID:	614574   Click image for larger version
ID:	614575   Click image for larger version
Old Jun 12, 2015 | 12:28 PM
robsjeep9's Avatar
JK-Forum Ambassador
Meh the rubicon lockers break all the time .... Build it like I did my 09 X model.... One step at a time as money allows and in the meantime enjoy what you have it's quite capable.... Easy in the Dana 30 tho ......
Edit: not the lockers itself but the wiring and connections can come loose resulting in temporary loss of use.... Happened to another one of my buddies this past weekend(trail fix)
