Do TPMS's....
Old Jul 2, 2013 | 08:48 AM
Chief_Airborne's Avatar
Vet Army
Default Do TPMS's....
...go bad? My light came on and all of my tires are sitting at 34psi. I know that is not low.
Old Jul 2, 2013 | 09:07 AM
Namtaru's Avatar
It's not unpossible, its a small piece of electronics.
I don't even use mine, i disabled them.
Old Jul 2, 2013 | 11:32 AM
Paul R's Avatar
Did you check the spare too?
Yes, TPMS's eventually go bad and need to be replaced. But that is usually after many tens of thousands of miles. If you are still under warranty, take it in.
-Paul
Old Jul 2, 2013 | 11:34 AM
Rule18's Avatar
I believe they have batteries in them so if they're old enough, yes.
Old Jul 2, 2013 | 11:38 AM
Yellowfin's Avatar
Yup....they eventually go bad. Just do away with them....unless you like the idiot light flashing at you when it gets cold.
Old Jul 2, 2013 | 05:09 PM
jwilson2598's Avatar
They will eventually go bad. The lifespan on them is 7-10 years if i remember right. I know i had to replace one on my CTS-V in 2011, and it was a 2004.
Old Jul 2, 2013 | 05:12 PM
RoysRig's Avatar
Mine won't turn the light off until I have 36 psi.
Old Jul 2, 2013 | 05:49 PM
Vet Army
I'll give it a try.
Old Jul 3, 2013 | 06:54 AM
Vet Army
That did it...I air'd them up to 38 and the light is off. Weird. Think I will have to disable those things...36-38 seems a bit high to me. Ride feels a bit harder.
Anyway, thanks for the all the helps, gents!
Old Jul 3, 2013 | 06:58 AM
Yellowfin's Avatar
Yeah 38 psi is pretty high. I'd spend $150 on an AEV ProCal (or find one used) and use it to set your TMPS to whatever pressure you want it to warn you at. Personally, I set mine to 0 so when I air down to 8-10 during wheeling trips, I don't have to look at that stupid light.
