Engine Compartment Cleaning Method
Old Apr 2, 2008 | 02:26 PM
Lorrel's Avatar
Originally Posted by Red Rubi
I use Super Clean, it's in a purple jug at the auto parts store. That stuff will remove anything including the skin off your hand. It works great, just don't apply and forget about it, also removes paint.
WOW. Wonder what it does to the wire and cable insulation in addition to all the rubber inside including the motor mounts.
Old Apr 2, 2008 | 03:13 PM
RedneckJeep's Avatar
Spit shine.
Old Apr 2, 2008 | 04:38 PM
Red Rubi's Avatar
I've used the stuff for over 5 years and never had any problems. If you leave it there and don't rinse it off, then you would end up with problems.
Here's what they say you can use it on : Auto Parts / Engines / Tires / Underbodies / Carpets / Rubber Floormats / Vinyl Seats / Dashboards / Upholstery / Chrome / Stainless Steel / Barbeque Grills / Chainsaws / Concrete / Lawn Mowers / Plastic Furniture / Pool Areas / Tools / Garbage Containers / Patio Umbrellas / Canvas Awnings / Drain Opener / Floorwax Remover / Garbage Disposals / Ovens / Scuffmarks / Fireplaces / Shop Equipment / Stove Hoods & Exhaust Fans / Tools / Appliances / Plastic Blinds / Pre-Soak Pots and Pans / Tubs and Showers / Vinyl Wallpaper / Laundry Pre-Soak / Microwaves & Stove Tops / Porcelain / Sinks / Counter Tops / Stainless Steel / Synthetic Carpet / Vinyl & Tile Floors / Walls.
Old Apr 3, 2008 | 08:30 AM
JK-Q8's Avatar
I just open the hood after the jk has cooled down the whole night and i just spray it witha hose? is that bad?
Old Apr 3, 2008 | 08:32 AM
JK-Q8's Avatar
I just open the hood and rinse it with a hose, not going to close to the air filter. Bad or good?
Old Apr 3, 2008 | 11:22 AM
urbikesucks
Guest
Posts: n/a
Default foam bathroom cleaner
I use the (when i was home) foam bathroom cleaner it's works great. I have also used it when we take out the dirt bikes to clean mud gunk ect.
