Engine light on dash came on.
Old Sep 23, 2009 | 07:22 AM
yellaRubi's Avatar
Default Engine light on dash came on.
I have about 22K miles on my Rubicon. The "engine" light on the dash came on. Owners manual says it may be bad gas, or gas cap lose. I put some high octane gas in, made sure cap was tight and still have a engine light illuminated.
Old Sep 23, 2009 | 07:57 AM
Can Handle the Truth's Avatar
You've probably busted your Evap canister. Crawl under the Jeep and take a look....you too can joing the busted Evap canister club. Welcome!
Old Sep 23, 2009 | 08:08 AM
ronjenx's Avatar
Why not see if a code has been set? There are too many things that will turn the light on to guess about it here.
1. To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
2. If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes as shown in the pic to the left. If your Jeep JK Wrangler has any logged in any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s) and check it/them against the list below to find out what they mean.
3. If your Jeep JK Wrangler has not logged in any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
Old Sep 23, 2009 | 11:09 AM
AK4Dave's Avatar
Yes.....what he said.
When my JK was still pretty new, mine came on. The dealer had a HELL of a time figuring out what it was....even replaced the PCU. They had to work with Chrysler for days. Ended up being a bad wire INSIDE a wiring harness. Anyway.....it can be an easy fix or a hard one.
You might also try to disconnect the battery for awhile and reconnect......see what happens.
