Foam kit?
Old Sep 25, 2016 | 04:12 PM
TMO84's Avatar
Default Foam kit?
The two pieces of foam on the softop door surrounds on my '13 JKU are peeling off and ripped to shreds. Mopar makes a "foam" kit and it's something like over $100. Not paying that for foam. Anyone ever replace these as a DIY?
Old Sep 25, 2016 | 05:14 PM
karls10jk's Avatar
I'm adding small pieces of foam to mine to divert potential leaks. I don't see why you couldn't do the same with some regular adhesive backed foam. It can be found by the window sealing/ air conditioning supplies in a store.
Old Sep 25, 2016 | 06:45 PM
2014Wrangler's Avatar
I have a similar issue, one of my foam pieces comes loose and starts blowing in the wind when I have the top off. So far I've been pushing it back down and have not had any leaks. I'm probably going to take Karls suggestion and add foam to it eventually. I have some left over from an AC install.
Old Sep 28, 2016 | 01:01 PM
warpeg's Avatar
This happened to me last summer. I bought a roll of the foam (maybe 1" wide, strong adhesive tape on one side). It did the job great! For the rest of last summer and all of this summer, it has held up very well. No leaks and no wind noise. For reference, I am constantly flipping my top up and down, so the foam gets plenty of action.
Old Oct 3, 2016 | 12:13 PM
rfogle's Avatar
If it has just come loose and you sill have all of the pieces you can use 3M Super 77 spray adhesive. Good stuff and if you prep the surfaces it will stick like new...
Old Oct 3, 2016 | 12:33 PM
casamtb's Avatar
Glue. Strong stuff.
https://youtu.be/Rq2FTWPYpqw
Old Oct 3, 2016 | 01:11 PM
Canvas's Avatar
Veteran: Navy
I have used the foam tape that is sticky on one side. You can get it in various widths and thickness from Home Depot or Lowe's in the door and window weatherstripping section. Just cut what you need.
M-D Building Products 1-1/4 in. x 30 ft. Camper Seal Foam Tape-02352 - The Home Depot
R/
Will
Old Oct 25, 2017 | 04:44 AM
Cutman's Avatar
Default Contact Bestop
I know this thread is dead and buried but I have new info that may help. I just had those foam pieces fall off. I went directly to Bestop to see if they would offer the parts or warranty the top. I emailed customer service with pictures and got this response within minutes.
"The part number is 526.72P cost is $7.95 plus tax and shipping"
I just got the order in the mail and it seems there are 6 pieces in it (3 on each side). All for the door surrounds. No instructions. One piece is the one I needed. One has two big round holes in it so I'm assuming it goes on the bottom of the surround where it attaches to the Jeep body. Don't know about the other one.
