Front doors off fine, back doors PITA
I'm on an almost perfectly flat surface my rear passenger side door WILL not budge, I'm a pretty strong guy too, I've tried to shoot some WD-40 up from below too once I took the torx bits out from the bottoms...any other suggestions?
Happened to me what I did was srew torx in about half way and with block of wood and hammer tapped torx head. Once it freed up pulled door right off. After got doors off sprayed some white lightning silicone on hinge and doors come off easy peasy now
Ya I greased up my front doors after I got them off and they popped off today no problem at all, also doest it seem like Chrysler should put the pronged part permanently on the side of the jeep, sticking up rather than on the door, sticking down... Feel like that would eliminate some of the difficulty getting them off and would certainly make it easier to put them back on
I made a couple YouTube videos breaking my doors loose. I used some liquid wrench, a car jack, and some towels to cushion the Jack under the doors. Give one pump with the Jack, and shake the doors back and forth. Repeat that process. The doors will come off. Just grab it before it pops off so you don't damage it. I'd roll the Windows down before taking them off too to help protect from breakage.
I now put anti seize on the doors before putting them back on. They come back off with ease now.
If they are really stuck and you use the jack method, you probably should have a helper. Place the board of the jack against a pretty strong part of the door--maybe not the pinch seam, which you wouldn't want to bend. Jack up and the vehicle may raise up. While you hold the door (window rolled down, gripping interior handle), have you helper push down on the Jeep--maybe on the front door sill. A couple good pumps should free up the door. If not, open or close the door some and try again with the door at a new angle--it may be that the pin and hinge are slightly out of kilter and you need to find the right spot to get them going the same general direction.
