front locker issues
Old Oct 8, 2013 | 08:00 PM
dcherico11's Avatar
Default front locker issues
I went to lock in my stock electronic front locker on my rubicon and it would not engage. I tried to drive back and forth as well to see if that would help but it didn't lock in either. I checked the fuses and everything looks good. I have not yet taken off the differential housing yet to look inside the unit. Is there something I can do as an easy check before I get into taking stuff apart? Has anyone had this problem with the stock lockers?
Thanks,
-Derrick
Old Oct 8, 2013 | 09:09 PM
Warcrimes7's Avatar
Hey there was a forum on this somewhere on the Internet not sure if it was on this site. From what I read it said to check fuses. Also check the wiring that connects to you e locker. A lot of the time they said it was a loose connection. Well hopefully it's something minor good luck with your fix dude.
Old Oct 8, 2013 | 09:31 PM
TURTLECON's Avatar
Check the connector on the diff to see if it's loose. If it's seated properly, then check the contacts with a voltage meter to see if it's getting juice.
