How Often
Old Feb 16, 2010 | 10:10 PM
Millerman999's Avatar
Default How Often
Should you re-fluid everything? Grease things up (lift maintenance) and check your jam nuts?
Old Feb 16, 2010 | 11:15 PM
Fishyguy's Avatar
I do all fluid changes at the recommended intervals and I grease everything and check all the suspension at every oil change
Old Feb 17, 2010 | 12:42 AM
Scrambled's Avatar
x2
If you get in the habit early there is less chance you will miss a small problem and have it turn into a bigger more expensive problem. It would be a good idea to keep a log of your maintenance and all the receipts, especially if you have lifetime warranty.
Old Feb 17, 2010 | 05:55 AM
toymaster's Avatar
An average of 2.5 per times a week
Oh, sorry thought you meant something else.
Old Feb 17, 2010 | 07:06 AM
Ok cool well fishyguy and scrambled how often do u do the fluid changes and when you get the Susp. checked do you asked them to do it too??? Even though i check mine a ton i dont always no wat to check.
Old Feb 17, 2010 | 09:55 AM
Rawb77's Avatar
Agreed. I'm not too sure where and what to check regularly. Would be nice if someone created a short printable pdf booklet with pictures of a quick step by step walkthrough on things to check on your Jeep that could be done weekly or whatever. Anyone up to the task? Would be a real good help for newbies such as myself.
You know, things like the Ball Joints and whatnot...one can read about them here on the forums...but not know what to look for or even where on their vehicle to see if they have a problem in the making!
Old Feb 17, 2010 | 10:06 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Every 3,500 miles if I'm lucky, I'll grease everything and check everything out.
Old Feb 17, 2010 | 10:10 AM
Piginajeep's Avatar
Did I meet you at 4wd the other day? you were wanting to talk with Bryan?
Anyways, I tighten and grease everything at the oil changes..
if i wheel, I check the torque on the suspension before and after
Old Feb 17, 2010 | 12:09 PM
PiginaJeep yes you did, haha im the kid getting all that stuff done here soon before Summer! Im actually going to order a rear bumper/tire carrier from you too, some new bumpstops, fender flares and some Control arm locks since the adjustable ones bolts always loosen up imma keep em on lockdown. But yeah thats Me. But when I mean fluid i mean like Transmition fluid and all that.
Old Feb 17, 2010 | 12:23 PM
Piginajeep's Avatar
I don't work at 4wd. I gave you matt peters number.
