How Often
I do it every 1500 miles.
Lube:
(you won't have any of this if you are stock)
Track bar Johnny Joint
Teraflex Control Arms
Aftermarket tie rod/drag link ends
JKS discos
Torque to spec:
Front Lower Control Arms - 125 ft lbs.
Front Upper Control Arms - 80 ft lbs.
Front and Rear Trackbar both ends - 130 ft lbs.
All rear control arms - 125 ft lbs.
Make sure discos are on tight.
I do not check torque spec on the tie rod/drag link as mine are aftermarket and have castle nuts on them.
Lube:
JKS discos
Torque to spec:
