The Importance of changing out stock track bar and lower control arm bolts
#511
Got mine installed
Santa (wife) was good to me. Received the NR4X4 bolt upgrade kit and installed with the help of my son within 4 hours of work time. No issues or noted wear on front track bar from stock bolts, but the new grade 8 bolts were a much better fit. Glad to have this done, and have peace of mind that it is right.
#512
A general question on this....
Since the bolts are a known issue and resolution....
Do after market trackbar kits have the correct bolts?
or...
If getting an aftermarket trackbar,
does one also need to buy the bolt kit additionally?
or...
#513
Most kits reuse factory hardware where possible.
#518
I am looking at the kit that came yesterday and have a question about it. According to the piece of paper that came with the kit, since my jeep is a 2012 it has to use 14mm bolts that are included in the kit. This is necessary because the 9/16 bolts are too wide...... My question is this.. There are only 2 14mm bolts. If the track bar bolts need to be 14mm, wouldn't I need 4? It is too early right now to call northridge because they are in Washington and I am in bama.....
Does anybody know which Mount of the trackbar needs to have the 14mm bolt in it?
Any thoughts?
Thanks for your help.
Any thoughts?
#519
One on the drivers side front for sure on an 11 and 12 model. The rear I can't remember, but there is no mistaking, the 9/16 bolt either goes in easy or gets hung on the shoulder. Don't force anything on the trackbars. The control arms could use some manipulating.
