The Importance of changing out stock track bar and lower control arm bolts
#491
Originally Posted by Ron Burgundy JK
Flat on the ground...
#492
I Need Help! I have changed out the front track bar bolts and the lower control arm bolts on the front, torqued them to spec and experienced death wobble this morning!!!
#494
Originally Posted by ncrubicon
To add to this, he has also checked the torque multiple times and is still getting death wobble. I believe that the lift only has around 3k miles on it and the JK itself also has low miles also. Which holes is he looking at? Is he actually looking at the control arms themselves are is he looking at the actual mounts on the axle?
#495
Originally Posted by 2010islander
If you didnt have death wobble beforeTry putting them back to the stock bolts. If it ain't broke dont fix it. You can tighten them down all you want but if there is movement or no movement at all you are going to have issues
#497
No death wobble before changing out bolts and now you have death wobble? That doesnt make much sense. Are you sure everything is tight? There is no reason why the new hardware would promote death wobble.
David
David
#498
#499
Originally Posted by JK-Rubi
Please note above highlighted text otherwise I'd agree with you David. By now his ball joints are probably shot with all that death wobble going on.
#500
