The Importance of changing out stock track bar and lower control arm bolts
Old 07-09-2013, 07:37 PM
  #591
jeep_n_co's Avatar
Anyone who has done this in the Denver area who would want to gift me their old bolt/nut setups? I just need one bolt and nut (with tag) for the rear lower control arm front bolt. For some reason, one of mine won't tighten up all the way (perhaps its cross-threaded - I blame my brother as he wrenched on that side while changing out LCAs).
EDIT: Thanks Ryan for the spares. Went ahead and ordered the Northridge kit anyway. Might as well fix it right.
Old 11-18-2013, 04:24 AM
  #592
magnum.pi's Avatar
Hi All, it's strange but it seems that in my JKUR'11 the bushing hole is for metric bolts: I bought the bolts kit last week and I tried the 9/16 on my old track bar frame side and it didn't work. Now I ve a monster TF track bar and I don't know it they work on it, I'll see.
Anyway, also on the other side the 9/16 doesn't work but the kit has only one metric bolt and then a question: is it possible to replace the nut on the axle side which has a "flag" , with a 9/16 normal nut or I need that flag?!
Old 11-18-2013, 04:33 AM
  #593
karls's Avatar
You can replace them with normal nuts but the flag nut will make your life less painful, even if you've got to weld a flag onto the new nut.
Sent from my DROID4 using Tapatalk
Old 11-18-2013, 06:23 AM
  #594
Forum Tech Advisor
planman's Avatar
The flagged stock nut is metric. You cannot use it with a 9/16" bolt.
If you upgraded to a TF front trackbar, drill out your frame side bracket holes to 9/16" so you can use the bolts that fit the trackbar bushing better.
Old 11-18-2013, 11:19 AM
  #595
spartan99's Avatar
Can someone post exactly what I need for the track bar and control arms? I want to fix this ASAP. Excellent thread!!
I found some posts that list the items but I cannot tell if it's for BOTH the track bar and control arms.
Thanks you guys on this forum are amazing.
Old 11-18-2013, 05:55 PM
  #596
Forum Tech Advisor
planman's Avatar
For the front trackbar:
  • 2-9/16" fine thread grade 8 bolts, 3" long.
  • grade 8 washers
  • stover lock nuts (not nylon lock nuts)
The front trackbar is the most important. Doing the front and rear lower control arms and the rear trackbar is less critical, but a nice upgrade.
Northridge4x4.com sells a bolt kit for all lower control arms and both front and rear trackbars for about $40. If your total order is $100 or more, free shipping. If your total order is $250 or more and you use the current promotion code, 10% off and free shipping.
Old 11-18-2013, 11:17 PM
  #597
magnum.pi's Avatar
So do you can confirm that in TF tb the bushing hole can run with 9/16"? I'm Asking 'cause I bought a spare bushing from TF that they say works both with TF and OEM tb but at the end it doesn't work with 9/16" bolts…so my doubt
Old 11-19-2013, 03:37 AM
  #598
Forum Tech Advisor
planman's Avatar
You bought a Teraflex bushing to run in your stock trackbar?
The only trackbar bushings that I know of that are not 9/16" are the frame side bushing in stock trackbars beginning around 2012.
Old 11-19-2013, 04:02 AM
  #599
magnum.pi's Avatar
Yes because in the TF description they say they are interchangeable… and what you said is, for me, correct, two bushings, spare and Oem, are the same, I don't know if TF has the same one. On the contrary actually I ve a matric bolt in the inch-bushing hole of my TF and this could explain my trobles!!
So I ve to drill the hole in frame side for sure? I was hoping the job was plug&play whithout additional work…
Old 11-19-2013, 04:08 AM
  #600
magnum.pi's Avatar
ah! My JKUR'11 had originally for sure a metric bushing hole both side in the oem track bar
Quick Reply: The Importance of changing out stock track bar and lower control arm bolts
