Jack Options
Old May 31, 2013 | 02:26 AM
16 Unlimited Ways's Avatar
Default Jack Options
Guys what's being used for jacking a lifted JKU...I have a 2 1/2 lift only with 35" tires...I did change both bumpers also...
When i go on trips i want to bring a hydrauilic jack or something fast that would lift...What's being used...
Old May 31, 2013 | 03:12 AM
carolinajk's Avatar
you can buy a baseplate for your factory jack that will raise it sufficient if u have a lift quadratec sells them
Old May 31, 2013 | 04:04 AM
jdk's Avatar
jdk
Hi Lift
Old May 31, 2013 | 06:16 AM
afpilot82's Avatar
JK-Forum Ambassador
Hi-lift is great for on the trail, but if you just need to change a tire on the side of the road, check out the AEV jack base. It's tucks nicely in the storage cubby in back and lets you use your stock jack.
Old May 31, 2013 | 07:44 AM
Rebelyell22's Avatar
get a bottle jack to keep in the back
Old May 31, 2013 | 09:18 AM
BigSteve's Avatar
I have the AEV jack base. Handy little piece of equipment. You can use it as a wheel chalk, it holds your wheel lock, pretty sweet little deal for $40 and it lifts my 37s off the ground!
Old May 31, 2013 | 09:21 AM
idiotec's Avatar
The stock lift will not go high enough with 35's?
Old May 31, 2013 | 09:43 AM
k0260's Avatar
I use AEV's jack base. Works perfect. Makes the OE scissor jack much more useful. @ 3.75" of lift on 35's.
Old May 31, 2013 | 11:16 AM
jk.bushwacker's Avatar
x2 This guy ^^ has got the right idea
lift wont affect a tire change, tire size is the only factor. you'll be jacking from the axles, right?
Old May 31, 2013 | 05:52 PM
idiotec's Avatar
How so? What does this do a couple pieces of 2x6's won't do?
Honest question, thinking about it but seems like a lot just to raise the stock jack a few inches.
