Jeep wave gets me in trouble
Found the Jeep Wave Rules.....
Top off: One handed wave above windshield or outside body tub
Top off during blizzard: Shiver and nod, hands may remain frozen to steering wheel
Southern/rural locations: Raise fingers from steering wheel, nod
It's not what you buy, it's what you build and what you do with it.
In keeping with this cardinal rule of Jeeping, categories have been established to account for each part of the equation.
These categories are:
The Jeep Waving Hierarchy: Based on the vehicle itself. Takes into account the nostalgia factor, the discomfort tolerance quotient, and the amount of owner dedication required to maintain the steed.
The Modifying Sub-categories: Based on what you do with your Jeep.
Equipment Adjustments: What you build.
General Rules:
1. All Jeepers are responsible for upholding the tradition of the Wave. Upon contact with a higher scoring Jeep, a Jeeper is required to initiate the Wave, and continue the Wave until:
a. The Wave is returned
b. The Wave is blatantly disregarded
c. The higher scoring vehicle has passed by and is out of sight
2. All Jeepers are required to return the Wave, unless the initiating vehicle clearly has a negative (below 0) score.
3. All Jeepers are encouraged, but not required, to return the Wave to negative balance vehicles, and take any opportunity presented to guide and mentor them about their responsibilities to their Jeeps in the hopes that they can correct the error of their ways.
4. When unsure of status or wave requirements of a particular encounter, or unable to completely assess the other Jeep's score quickly enough to ensure that the proper Jeep Wave Etiquette rules are followed, immediately initiate wave. It is the spirit of waving that is most important so when in doubt:
Just Wave!
First, the Jeep Waving Hierarchy (JWH):
Category A - Pre-CJ (Willys/Kaiser/MB/etc): 30
Category B - Pre-AMC CJ: 27
Category C - CJ: 25
Category D - Commando: 20
Category E - YJ: 16
Category F - TJ: 15
Category G - Cherokee, Wagoneer: 10
Category H - All other Jeeps: 5
Category I - All other 4WD vehicles EXCEPT yuppie Explorers: 0
Category J - All other vehicles
The Modifying Sub-Categories (MSCs):
(What you do with it)
MSC Guidelines:
1. MSCs must be considered during all Jeep encounters, and wave patterns must be adjusted accordingly.
2. MSC 5 is the median - the accepted norm.
3. MSCs from 1 through 4 will increase score as listed.
4. MSCs 6 and 7 will decrease score as listed.
MSC 1: Top off; vehicle, driver, and all occupants covered with mud: +30
MSC 2: Top partially off; vehicle and some occupants covered with Mud: +20
MSC 3: Top on; vehicle covered with mud: +10
MSC 4: Top off during snow, sleet, hail, or heavy rain: +5
MSC 5: Somewhat dirty: 0
MSC 6: Obviously recently washed, but immediately re-muddied a little: -10
MSC 7: Clean, dry, unscratched, untested: -30
Equipment Adjustments (EAs)
(What you build)
Consideration must be given to the current mechanical condition of the vehicle, including all modifications for trailworthiness, comfort, appearance, and spouse-appeasal. These are known as Equipment Adjustments (EAs). EAs are only granted after the work has been completed. We all have plans for EAs, but only the ones actually implemented can be scored.
EAs are a complicated category, and often difficult to appraise under certain conditions (passing head-to-head at 60 mph, when covered with mud, etc) but must be used to modify score when feasible. If a vehicle is so covered with mud that you are unable to ascertain any of the EAs, you MUST assume that the EAs, when combined with the MSC 1 adjustment, would place the vehicle in a higher scoring position than any non-MSC 1 Jeep, and immediately initiate the wave. Otherwise, EAs will adjust score as follows:
Engine:
Stock, Pre-CJ, Working Condition: +2
Stock, 8-cyl: +2
Stock, 6-cyl: +1
Stock, 4-cyl: 0
Replaced, 8-cyl: +3
Replaced, 6-cyl (replacing 4-cyl): +2
Replaced, 6-cyl (replacing 6-cyl): 0
Replaced, 6-cyl (replacing 8-cyl): -1
Replaced, 4-cyl: -1
Drivetrain Modifications:
Improved internal mechanical parts (crank/cam/etc): +2 each
Upgraded Transmission: NV4500 or Turbo400: +3, All others: +2
Upgraded Transfer Case: +2
Improved exterior mechanical parts (headers/manifolds/pumps/filters/etc): +1 each
Stone stock in a pre-1970 vehicle: +3 (for nostalgia and historical analysis)
All Comfort enhancements removed for more power: +2
Tires:
Stock or unremarkable: 0
Original Tires on Pre-CJ: +2
Slightly oversized (up to 31"): +1
Over 31, with other appropriate mods: +2
Any size, currently covered with mud: +2
Working tires > 31" with original donut spare: -2
Low-profile: -10
Suspension:
Stock, Pre-CJ: +2 if driver can still walk after an hour in the saddle
Body lift: +1/inch
Suspension lift: +2/inch
Spring-Over Lift: +3
High-quality shocks: +2
Lowered: -20
Other accessories/conditions:
Winch, heavy-duty, obviously used: +2
Winch, heavy-duty, use unclear: +1
Other winch, obviously used: +1
Little, chrome-covered, toy winch: -1
Lockers: +2
Upgraded axles: +1
Upgraded transfer case: +1
Each chrome accessory currently shiny: -1
Each neon accessory: -2
Fire extinguishers: +1
Block and Tackle, anchors, etc: +2
Ropes, straps, tow chains: +1
Tow Hooks: +1
Nerf Bars/Rock Rails, used and scarred: +2
Nerf Bars, shiny, no scars: -1
Heavy duty bash/skid plates: +1
Other protective plating (diamond plate, etc): +2 if scarred, -2 if unscarred
Extra fuel tanks/oversize fuel tanks: +1
External Gear Carrying Rack: +1
Multi disc-CD Player: -1
More than one subwoofer: -1 each
First Aid Kit: +1
Backpack, food, emergency gear (just in case): +2
On-board air compressor: +1
On-board Welder: +2
Girly, shiny chrome center caps: -1
Krylon home-made paint job: +1 (for realizing it's just going to happen again)
Blackout Headlight Covers: -1
Any little flippy interior vanity mirrors: -1
Children in vehicle: +1/each (for proper training/indoctrination), +2 if muddy, an immediate correction if not belted in.
EARNED trip stickers/badges/etc: +1/each
Unearned stickers/badges/etc: -2/each
Stickers advertising for other than 4wd-related businesses: -2 (except No Fear: -5)
MSC 1 vehicle in corporate lot sharing with neighbor vehicles: +1 per vehicle decorated
Correct mental attitude, seen or proven: +3
Windshield down: +1 (+2 if raining/snowing)
Bugs left on face/teeth as evidence of recent windshield down driving: +1 (+2 if more than a week old)
CB radio or other communication tool (for emergency only): +1
Hi-Lift Jack: +2
Flexible caulking to fill leaks and body damage: +2
Dogs as passengers, properly secured: +1 (sharing the joy of Jeeping)
Bringing a new Jeeper into the Family: +5
Extra Lighting, used for night-wheeling, not pastel or neon colored: +1/ea
Original military machine gun on Category A Jeep: +30
Battle Scars:
Mashed hood, top, etc., obviously from roll-over: +3
Holes above glove box where passenger ripped grab-bar out: +3
Heavily gouged rocker panels: +2
Bloody seats: +2
V-bent front bumper from being pulled out of that REALLY bad one: +2
Scarred sides from those mis-judged rocks: +1
Any small parking lot dent/scratch still identifiable: -1
Other accessories bent, folded, mangled or mutilated: +1, EXCEPT:
See above, but said item is owned by your spouse: +2
No scars whatsoever: -3 (Unless Pre-CJ restored, then: +3)
New body due to rust only: -5 (unless a rescue, see discussion below)
New body due to damage: Previous damage points carry over (see discussion below)
Fire Damage (bubbled paint, singed seats, etc): +2
Limbs, Shrubs, etc attached well enough to remain at highway speed: +1/each
Disclaimer
Each Jeeper must interpret the rules as they see fit. If there is a dispute, or if you have a question regarding your score, I will be happy to give you my opinion, however, Jeepers are strongly encouraged to follow the spirit of the rules and Just Wave whenever in doubt.
General Rules:
Just Wave!
Category C - CJ: 25
Category E - YJ: 16
Category F - TJ: 15
MSC Guidelines:
(What you build)
Engine:
Stock, 8-cyl: +2
Stock, 6-cyl: +1
Stock, 4-cyl: 0
Replaced, 8-cyl: +3
Replaced, 4-cyl: -1
Tires:
Low-profile: -10
Suspension:
Body lift: +1/inch
Lowered: -20
Lockers: +2
Upgraded axles: +1
Tow Hooks: +1
First Aid Kit: +1
On-board Welder: +2
Hi-Lift Jack: +2
Battle Scars:
Bloody seats: +2
Disclaimer
I used to wave to all the other Porsche's when I had one of them too, so my wife already knew this was something that was out there. But she sure loves the waves at her when she drives the Jeep so she doesn't complain.
as for the dorrs off down low wave, It is showing off. I do it too.
that's how us bikers wave at eachother. i didn't even realize i do it differently with the doors off. it just makes sense?
We have a thread on here titled (something like) Hot girl and JK or something. There is also the eyefull thread for this.
I knew someone would post the jeep wave rules agian. Will you please quit posting it because it is ridiculous. By the time I do all the adding and subtraction (including taking off shoes so I can count that high) we have long since passed each other.
