Jeep wont go WOT?
Old Aug 26, 2010 | 12:05 PM
  #21
racinfast002's Avatar
Originally Posted by JEEP THRILLS
this is good info.
so would it be possible to create more vaccuum somehow
is intake design the only way or larger throttle body or a spacer wich I always thought were total snake oil
as I understand it, the throttle plate isn't open all the way because it doesn't need more air.(perfect fuel to air ratio)
adding more fuel won't help at this point because you are at 0 vac.
exactly! Not sure what you would do to make it require more air other than more stroke/bore
Old Aug 26, 2010 | 12:14 PM
  #22
aside from ramming it in via turbo or super.
reminds me of the viper throttle body saga. they say a bigger throttle body won't alow more air.
well does not a larger garden hose alow more water, could i not fill a bottle faster if the hole at the top was bigger.
I realize there are many other factors like pressure and volume
plus if our little T/B doesn't need to open all the way, the viper one would be a waste but our 3.8 has room for improvment.
