Jeep won't start and ETC light is on!
Old May 26, 2012 | 05:53 PM
JK08KATYTX's Avatar
Default Jeep won't start and ETC light is on!
Haven't notice my jeep running rough or anything odd, but just went to move it and no cranky. Just a click and the electronic throttle control light stays lit up. What are my options and PLEASE say there is something besides "take it to the dealer" because its not under warranty any more
Old May 26, 2012 | 06:21 PM
Saharaunlmtd's Avatar
If its an auto, push forward on the shifter and give it a crank.
Old May 26, 2012 | 06:22 PM
Sharkey's Avatar
Did you try disconnecting the battery for 20 minutes or so just to see if you got a weird electrical glitch?
Old May 26, 2012 | 06:23 PM
jrhsvt's Avatar
cheap and easy first; test battery at autozone. My last 08 did that, lights were plenty bright, etc...put charger on anyhow and still nothing. turns out battery had bad cell; enough juice for everything except to crank it.
Old May 26, 2012 | 06:24 PM
JK08KATYTX's Avatar
It is an auto but that didn't do anything. Thanks anyway
Old May 26, 2012 | 06:28 PM
JK08KATYTX's Avatar
I will try disconnecting battery and yea I was thinking about having the battery checked tomorrow before freaking out. Luckily I'm not stranded anywhere, I'm home
Old May 26, 2012 | 07:05 PM
JK08KATYTX's Avatar
Clickity, click...looks like I'm going to autozone tomorrow. Thanks for the ideas
Old May 26, 2012 | 10:47 PM
owntmeal4life's Avatar
I had a battery cell go out on me with my 08 check and see if there's a batteries plus near by I got a good deal on mine bout 30 dollars less then autozone
Old May 26, 2012 | 10:54 PM
cuongdyna's Avatar
I had the same thing happen to me. It would just click but wouldn't turn over. I had to take it to the dealer 4 times. They check everything. They change out the starter, battery, and coil in the trans.
It turn out to be ground problem. They added another ground cable from the engine to the nagative on your battery. Hope this help.
Old May 26, 2012 | 11:30 PM
Kerrazy's Avatar
What year is yours? I have an 11 and it did this to me just last week at a friends house I have the dull batteries and everything I took the cable off the battery for a few then put it back on and jump started it it's been working fine since not sure what the deal was but since you said that about the grounding i know what I'm doing this weekend
