Jeep Wrangler JK Wheel Spacers Pros and Cons
I have an Unlimited JK with stock rims and 2inch lift. I have seen some of the pros and cons of using wheel spacers but most of the forums are for modified OEM wheels and tires. I just wanted to see if anyone else uses wheel spacers with stock wheels and stock/all terrain tires. Images before and after would be great too. Thanks.
Plenty of people run spacers without any issues, Spidertrax 1.5" tend to be the most popular for good reason. Install them correctly, recheck the nuts at regular intervals and you'll be fine. Don't cheap out and buy no-name eBay spacers just to save a little.
Wheel Spacers Pro/Cons (Most of this I don't understand)
https://www.youtube.com/watch?v=hWijfooeSyU I'll be running stock wheels/tires with spacers shortly due to I'll be installing a lift and won't be getting new wheels/tires until sometime after installing the lift and most have indicated I will likely need spacers with the lift due to potential rubbing on the rear sway bars.
YouTube Link: https://www.youtube.com/watch?v=hWijfooeSyU
We have 2" spacers in all three of our Wranglers, two Rubicons and one Willys.
We all have the stock runs and tires in and haven't had any problems whatsoever.
Spacers will always be on my must have mods. They make the wranglers so much better looking and driving.
That's what I was thinking about doing as well. I found some spacers that come with a leveling lift kit to add height and wider stance while still using stock wheels and all terrain Nitto Grapplers. I found another thread that showed a 2 inch lift with 1.5 inch spacer. I may go 2.5 inch and 2 inch spacer. It would prevent any wheel rub and add to the looks of the Jeep.
I'll be the odd man out and say that running spacers is a certified bad idea, but of course so is running non-stock offset wheels for all of the same reasons.
Seems Jeep guys don't bother to think about anything except appearance when choosing wheels, lift, etc., and then try and justify poor choices by claims of improved off-road performance but wheel spacers are going to reduce performance in pretty much every measurable way with almost no upside performance-wise except for increased tire clearance, which you won't need anyway if you don't run larger tires.
I'm firmly in the "if it ain't broke don't fix it" camp. I would never argue that Jeep have done a great job engineering the suspension on the JK, which is archaic at best, but it certainly can't afford to be made any worse by ill-advised mods, even if virtually every Jeep enthusiast does these mods regardless of performance side effects.
FL-GA (03-15-2022)
I'm not so much suggesting that there will be a high instance of catastrophic failure, but more suggesting that there will be a reasonably increased chance of catastrophic failure and notably reduced durability along with a constant decrease in performance. There really is no upside, besides someone's subjective idea of the appearance.
And by the way I made this same argument with people running the wrong offset wheels on Miatas just because they like that "wheels stick out" look and would say the same thing about the wire-wheels-sticking-out-from-your-monte-carlo fad of 15 years ago. All of this has the same negative effect on performance and durability for the misguided purpose of different appearance. IMHO.
I say leave it alone. Nothing wrong with a stock Wrangler.
FL-GA (03-15-2022)
