JK wont turn over or give me codes
Does it click when you turn the key?
Do you have an automatic? If so, move the lever to neutral and try it. Or, push it more into Park and try it.
Other than that, faulty ground wire connections may be the culprit.
What year is yours, your battery could be approaching EOL.
Take a jumper cable and go from the battery NEGATIVE terminal to a mount bolt on the alternator bracket. If that works, the problem is bad ground wires/connections.
How old is your battery?
Fill out some of your vehicle information on your profile.
yeh, head over to sears and get yourself the diehard platinum. You can spend hours here reading about all the things it might be, and honestly, it might, but go for the most obvious first. Remember Occams Razor, when faced with competing hypotheses that are equal in other respects, selecting the one that makes the fewest new assumptions.
