JKU issue with idle
Old May 15, 2014 | 06:55 PM
DenverRyan79's Avatar
Default JKU issue with idle
Hi guys I have a 2007 JKU with 110k. I recently put 20 bucks of gas in it after on the highway I had a cyl 6 misfire so I pulled the plug and it was pretty worn out. I replaced all plugs and wires and gapped to .05 I also used champion plugs and put some fuel treatment in. It seems I got misfire to go away but at idle it almost lopes and feels as it wants to miss and bog down. Any of you guys had any experience with this?
Old May 15, 2014 | 07:01 PM
jeeperjkjeeper's Avatar
is the gap supposed to be .030-.035? try running a bottle of Seafoam through your intake....worked wonders for me
Old May 15, 2014 | 07:07 PM
I was told .04 -.05 but I can try that and are you spraying through TB or somewhere else ? I'm really confused I'm pretty sure I didn't mess up firing order or anything in that nature.
Old May 15, 2014 | 07:12 PM
from my AllData...you are correct on the gap...
use the vacuum line on the brake booster to slowly suck in the Seafoam treatment
Old May 15, 2014 | 07:15 PM
Attachment 553154
You think it could be anything else just because it never really did anything like this before ...hmmm. Thanks for info
Old May 15, 2014 | 07:25 PM
sounds like it could be your pcv valve....easy and cheap to replace
Old May 18, 2014 | 08:51 PM
So after seafoam plugs and wires and pcv valve I just got a cyl 6 misfire today. Any other ideas guys.
Bump
Old May 21, 2014 | 11:36 AM
Bump
Bump bump
Old May 21, 2014 | 11:50 AM
Huntphreak's Avatar
#6 injector
or fuel pump.
you need spark, fuel and air for combustion.
sparks been checked
air is probably not the problem
Old May 21, 2014 | 06:58 PM
Originally Posted by Huntphreak
#6 injector
or fuel pump.
sparks been checked
I'm thinking it's a pump due to bad gas
