Just ordered 2010 Rubi, have questions...
I just ordered a 2010 Rubi, there were no dealerships that had what I wanted, so I did a factory order:
What I ordered:
-6 Spd.
-Deep Water Blue.
-Soft Top
-Side Airbags
-Tow Pkg.
That's it. My dealer didn't give me a whole lot of options when I ordered it. However I have some questions that I could not find a good answer through searching:
1. I do not have room for the hard top right now, but I am concerned about the wiring for defrost and wipers in case someday I do want the hard top. If I don't order the hard top now, will it be missing the components to put the hard top in later? I know the components that are necessary to put in the soft top.
2. The Satin Carbon Rims. Does anyone know the option code for these? The dealer did not give me the option when I ordered?
3. Will the soft top come standard with the tinted plastic windows or will I have to specify those at the time of ordering?
4. I didn't get the nav or upgraded sound because I have an aftermarket Nav/DVD head unit out of my current X that I will be transplanting into the Rubi, will the fact that the Rubi comes standard with the Infinity system mean that there is an amplifier in the way of me using the same setup of will I have to re-wire completely?
5. Are there any other hidden options I should be looking for when ordering.
What I ordered:
-6 Spd.
-Deep Water Blue.
-Soft Top
-Side Airbags
-Tow Pkg.
Now I'm certainly confused, or I'm being confusing in regards to the stereo.
The stereo that I will be getting with the Rubi will be the infinity, my question is can I remove the factory unit, put my DD Aftermarket unit that I have in my X in there and have the factory amp running still? Remember that I have a canbus adapter on there to make it work with the X and I assume that I'll need an adapter like you mentioned or the C2R-CHY4.
I assume that the inputs to the factory infinity amp are line level vs. high level and that if I try to hook directly up to the factory amp input wires, it won't last very long befor the amp dies, plus it probably needs a canbus signal to turn on the amp anyway, and without the proper adapter it won't work.
What confuses me is that it sounds like you're saying that after I get something like the C2R-CHY4 and plug my factory head unit into that, I will still need to get some sort of programming from the dealership to make it all work?
My questions about the hard top were to help me determine if it's a better deal to get the Hard top now (not the dual top group because I have no room) with all the wiring programming, etc... now, instead of later, and then buy the soft top later from a forum member used.
For example.
Factory Soft top now = $0
Add Hard top used = $1200 (top), + $150 (harness) +$75 (install)
Total = ~$1400
OR
Factory Hard top now = $654
Add Soft top used = $800
Total = ~$1400
VS.
Dual top group now ($1440) Which I don't have the room for so can't do.
In your opinion, what's the easiest option of the first two?
For example.
Total = ~$1400
OR
Total = ~$1400
VS.
Dual Top
I got the dual top. Wish I had just gotten the hard top and then purchased an after market bikini top. The soft top takes up a bunch of room with the hard top on. Soft top windows are still in the box, in the garage. They take up room, too.... I don't recommend purchasing a used hard top. You may find that doing so may prevent you from getting any possible noise or leak issues repaired under the warranty.
FWIW my .02
FWIW my .02
Seeing that you live in PA I'd order the Freedom top cause you'll pretty much want it for winter. Also adding a hard top later and using the wiper/defrost I believe would require a different stalk om steering column. The wiring though might already be there but still sounds like a headache to get everything right.
Simply get every option.
Dual tops in a cold climate are a must. I run hard top in the winter and soft top in the summer.
-possiblities are endless. The hard top is great during the winter and long road trips year round.
-dogs love the soft top when you drop the top or remove the windows.
-I like the soft top better than a bikini top as you can put it back up if it rains.
-I love runing soft top up, windows out and no doors when I'm on trail rides. Ultimate safari set up.
I'm kind of past the aftermarket stereo phase in my life, so I went MyGig. Totally happy with it....especially with the breadcrumb function.
I'd also add the tow package just in case.
I'm glad I have the 6MT, but kind of miss my remote start that I had on my Commander. I would have gone auto with remote start if the auto tranny would have been 5 or 6 speeds vs the 1980's 3 speed with OD.
I can live with it as the JK will become a weekend vehicle some day.
All of these questions may be mute as it sounds like you already ordered. Do you still have time to change your mind?
Regardless, good luck with it. I loved that I special ordered mine simply because the window sticker had my name on it.
In regards to the MyGig, I have a 09 Town and Country with the MyGig and although it's a perfect setup technologically, IMO, it does lack the sonic quality I desire. Which in a Jeep is a bit of a futile pursuit. Plus I can't stand the features being disabled in motion (I know lockpic will fix this, but I don't want to mess with it while under warranty unless I'm pulling the whole thing.)
your aftermarket stereo will work fine with your infinity amp .. no problem.. no need to to take it to the dealer to reprogram. have fun with your new rubi ! oh i would get the hardtop now if you can and pick up a used softtop for 400 - 500 bucks
Sooooo, Since I'm in D-1 it's too late to get my hard top, oh well, I've made due up until now with the soft top, I'll make due again.
Thanks for the input. I'm still torn on what to do with the stereo, I'll just give it a shot and see how it works I guess.
Thanks,
