Lift Install
Lift Install
Who on here has actually installed there own lift kit. I ordered my RE 3.5 Superflex yesterday. I'm a very cappable DIYer but by no means a mechanic. I have the tools, I have the jacks and jack stands. Just don't have the confidence to start tearing apart my new jeeps suspension. I've done all the reading on the subject.
How easy was it for everyone else. Maybe just need a lil "go for it" motivation!!!!
Eternal ***erator
I did mine by myself (twice... first a BB, then a coil lift with flex arms) I am no mechanic, but i have some tools and a curiosity/drive to do things for myself. Sometimes that gets me in hot water, but the lift went well, it just took me a long time as i went slow and double/triple checked everything as I went.
With 1/2 an ounce of mechanical aptitude you should have no problem doing it. As mentioned, go through some walkthroughs here to familiarize yourself with the process and take your time. I'm totally guilty of not doing it myself but only because I'm a lazy bastard and I only paid 1hr labour for someone to do it for me.
Eternal ***erator
I read the 4" Full traction and Tera lift installs until i knew the steps by heart, knew what i needed etc. but then i did it while i waas researching what i wanted. I am glad i did because i learned a LOT about my suspension and i know where theings go and how they work and interrelate now far better than i ever did. i would highly recommend doing these things yourself or with a competent buddy, it is invaluable experience.
whatcha gonna do if it breaks on the trail? you cant call the install garage to come fix it, your on your own. IMO better to know up front than then.
not quite a lift kit but i put rubi springs and shocks from a 4dr/hardtop/tow package onto my 2dr x and it was a breeze. gained an inch and a much better ride off road.
Eternal ***erator
I am certainly not mechanically gifted, don't do it for a living and don't have a something that resembles a shop, but I've installed a couple of lift kits in my Jeeps over the years.
It is a great learning experience as everyone says and you will gain understanding of how your Jeep works, but if this is your first lift, I suggest that you take it to a qualified offroad shop for inspection and alignment afterwards.
They can spot potential trouble areas or something that you did not install or torque properly quite easily since they work on Jeeps every day.
Also, inspect your Jeep for loose or worn joints before you install the kit. It may save you some headaches aferwards such as DW.
