New Fox Steering Stabilizer release?
I wonder if we will find them cheaper, by like a hundred or so bucks a few months down the road. Trying to inflate the price before the competition puts them on their site too. If so...that vendor won't see any future business from me.
Copied from an old jpmagazine article:
FOX Racing Shox Performance Series trough shaft damper (TSD) steering stabilizer.
The TSD is very similar to a motorcycle steering stabilizer.
Solid and rigid mounted with spherical bearings forcing all of the wheel feedback into the TSD damper for complete control.
Clockable piggyback remote reservoir with Internal Floating Piston or “IFP” design separates shock oil from the high-pressure nitrogen charged gas chamber filled to 400 PSI eliminates oil aeration while providing a predicable ride capable of handling the roughest conditions with fade free performance.
Through Shaft Design provides equal damping force and pressure in both directions eliminating veering or pushing during on road driving.
24 clicks of “free bleed” adjustments from a very firm to a very free steering wheel feel accommodating any driving style on or off the road.
Specially designed stabilizer piston allowing for increased damping force at lower shaft speeds allowing for a consistent road feel at any speed.
An energized piston sealing o-ring is installed between the piston and wear band for a complete and total seal providing improved road feel through a wide range of temperature change.
CNC machined Aluminum components are Type II hard anodized to a scratch and fade free finish.
6061 T6 Aluminum 2.0 stabilizer body dissipates heat three times faster than a conventional steel body stabilizer.
FOX FACTORY racing formulated shock oil developed for ultimate performance at variable temperatures.
Large heavy-duty 5/8” chrome shafts are induction case hardened to over 55 Rockwell C virtually eliminating scratches caused by roost and debris.
Redundant sealing pack system that includes three individual shaft seals keeping the oil in and the dirt out for continues reliable performance. (Main seal, wiper seal, scrapper seal)
Many Thanks,
Brian Godfrey
Marketing Manager - Powersports Division
FOX RACING SHOX
Many Thanks,
Brian Godfrey
FOX RACING SHOX
The truth is even a perfectly set up suspension can benefit from a steering stabilizer. The stabilizer's job is to reduce road influences from turning into steering wonder. By road influences I mean pot holes, dips, and uneven pavement. If you always drive on perfect mall parking-lot pavement with your jeep and are okay with white knuckling the steering wheel at every little bump, then you don't have to worry about the quality, (or even the existence of you steering stabilizer). I on the other hand allow my jeep to see primitive roads. I also like to be able to hit a pot-hole and have the jeep track straight without the need of a major steering correction. For this I employ a quality steering STABILIZER... you know to "stabilize" the twitchy responses caused by real-world roads.I'm not saying the JK doesn't benefit from a SS, but it certainly isn't an necessity given the proper attention to more important areas of the suspension. However, the JK doesn't need an aftermarket one, especially one with a $369 price tag. The stock one is more than adequate, especially relocated above the drag link.
Exactly. You can get lot more done on, to, and for your JK for $369.
Holly-Crap!
$370.... Pass. While I feel there is a difference in a quality vs. cheap stabilizer this one better be gold plated! There are a lot of really good alternatives for less than $200. (Which includes the relocation brackets. I think this one is targeted for guys with far deeper wallets than I have!
