New Jeep Project
I have recently purchased a 2008 jeep wrangler x 2 door and i am a beginner at building my jeep up and am all ears for input suggestions and opinions. I am currently looking at a 3.25 inch rough country suspentsion lift and looking at putting 33inch or 35inch bfgoodrich all terrains on it. does anyone have any suggestions on if i should or should not go that route. i plan i doing a little bit of offroading but nothing to crazy. im not trying to spending thousands on a lift.
thank you for your time.
Another route if you wanted to keep costs down is the Teraflex Budget Boost with shock adapters and a set of red Rubicon shocks. With this setup you could run a 33" tire an be able to disconnect the front swaybar. With wheel spacers or 4.5" backspaced rims you shouldn't have any rub.
You could also run a 35" tire with that setup. With wheel spacers or a 4.5" back spaced rim you shouldn't have any rubbing. But not able to disconnect the front swaybar with the 35's as you would have major rubbing issues.
Best of luck with your build!
Teraflex budget boost and some 33s. This will get you started and allow you decide where you want to go next. It won't break the bank and you won't kick yourself when you switch it out with something else.
