Noticeable difference between a 3.73 & a 3.21?
Old May 5, 2012 | 08:07 AM
  #51
new wrangler guy's Avatar
Originally Posted by dirtrider
My only complaint about the 3.21's is that even though they put the tow package (not max tow) on our jeep and we had to pay for it...it is useless with only a 1000 lb rating. The max tow has the 3.73's and it is rated at 3500.
According to the jeep website all wranglers are rated at 2000
http://m.jeep.com/en/jeep_capabilities/towing/
Old May 5, 2012 | 07:08 PM
  #52
dirtrider's Avatar
Explore Jeep Capabilities | Towing Reference Guide | Jeep
Hmm... my manual says 1000?
Old May 5, 2012 | 07:10 PM
  #53
aekdbrich's Avatar
I've heard 1000... but I'm pretty sure that's for the 2 door. The 4 door is rated at 2000, I think.
  #54
dirtrider's Avatar
Also, that shows what the maximum towing could be with the correct package. If you click on Wrangler unlimited it shows 3500 for all models with the optional max tow package.
Old May 5, 2012 | 07:19 PM
  #55
JKosmos's Avatar
True, with MAX tow. Max tow bumps you to 3.73's. Too bad that the suits made figuring out the tow pkgs and ratings similar to doing oragami with wet toilet paper.
I've always said that the secret to towing is knowing. Knowing how much is too much, how to balance a load, and how to drive it. If I can drive 97,000lbs and not destroy anything then I can hook a sensible load to my JK.
Old May 6, 2012 | 06:44 AM
  #56
dirtrider's Avatar
I agree. The weight balance of a trailer makes a huge difference... not only in how your vehicle will handle but also the performance. I recently towed 5 ***********s and a dirtbike on an 18 ft car hauler. I noticed I had way too much weight up front on the tongue making the truck squat. I got about 12.5 mpg going up on that trip. On the way home I switch the atvs around and got more of the weight towards the back of the trailer. I got 15 mpg going home.
  #57
dirtrider's Avatar
Does jk forums not like the word four wheelers?
Old May 6, 2012 | 07:52 AM
  #58
redunlimitedguy's Avatar
I believe they don't. I wrote it in a thread and they starred it out also
Old May 28, 2012 | 07:00 PM
  #59
JKRescue08's Avatar
There seems to be alot of debate about the 2011 and older 3.21 gears. I have an 08 X with 3.21's and recently installed my buddies mb72's with 33x12.5x15 duratracs (not sure if it was the weight savings from the 15" wheel) but I got around just fine for 3 weeks and barely noticed a difference.
the jeep does just fine for commuting and the occasional off-road camping excursion.
I have also tried his new set of 35's on my jeep and that is where you will find yourself kicking your feet to keep up with the prius.
