Oil pressure
Old Nov 26, 2013 | 04:44 PM
tecnorod's Avatar
Default Oil pressure
I have a 2013 wrangler. The oil pressure hits max 99psi while warming up. Is that too high. It has 7000miles
Old Nov 26, 2013 | 04:53 PM
TheDoubleD's Avatar
How do you know the oil pressure?
Old Nov 26, 2013 | 04:58 PM
tecnorod's Avatar
. The gauge. I had a check engine light. I scrolled thru the menus and found Oil pressure at 99psi, max for the gauge. Took to the dealer and they replaced the oil pressure sender and cleared the code but pressure still reads high
Old Nov 26, 2013 | 05:30 PM
ronjenx's Avatar
Your oil pressure seems to be right where it should be.
The 3.6L engine has 3 oil pressure ranges based on rpm.
600 - 1200 rpm = 5 psi (warm) to 139 psi (cold)
1201 - 3500 rpm = 30 psi (warm) to 139 psi (cold)
3501 - 6400 rpm = 62 psi (warm) to 139 psi (cold)
Was the code you had oil pressure related? If so, is it still a current code?
There are some things related to oil viscosity, filter installation, correctness of the filter, that will set an oil pressure code.
Old Nov 26, 2013 | 05:37 PM
tecnorod's Avatar
Originally Posted by ronjenx
Your oil pressure seems to be right where it should be. The 3.6L engine has 3 oil pressure ranges based on rpm. 600 - 1200 rpm = 5 psi (warm) to 139 psi (cold) 1201 - 3500 rpm = 30 psi (warm) to 139 psi (cold) 3501 - 6400 rpm = 62 psi (warm) to 139 psi (cold)
. I guess I'm good. Thanks I had concern with leaking seals
Old Nov 26, 2013 | 05:40 PM
tecnorod's Avatar
Never below 35psi warm at idle
Old Nov 26, 2013 | 05:41 PM
tecnorod's Avatar
Your oil pressure seems to be right where it should be. The 3.6L engine has 3 oil pressure ranges based on rpm. 600 - 1200 rpm = 5 psi (warm) to 139 psi (cold) 1201 - 3500 rpm = 30 psi (warm) to 139 psi (cold) 3501 - 6400 rpm = 62 psi (warm) to 139 psi (cold) Was the code you had oil pressure related? If so, is it still a current code? There are some things related to oil viscosity, filter installation, correctness of the filter, that will set an oil pressure code.
Code P0520
Old Nov 26, 2013 | 05:43 PM
tecnorod's Avatar
Oil and filter 2000 miles back, jeep dealer. Code was cleared
Old Nov 27, 2013 | 03:50 AM
Mark Doiron's Avatar
Your Jeep came with an oil pressure gauge? Or are you saying that it has a pressure sender (not the idiot light switch the earlier models had), and that it is accessible only through menus? Curious, because something like Android Torque Pro might give folks an OP gauge if so.
Old Nov 27, 2013 | 04:07 AM
tecnorod's Avatar
This is the 4th Jk I've owned and the first withe many more options, 13, 10 yr anniversary rubicon it is the only one the engine gauges, to include trans temp
