Oil pressure
The 3.6L engine has 3 oil pressure ranges based on rpm.
600 - 1200 rpm = 5 psi (warm) to 139 psi (cold)
1201 - 3500 rpm = 30 psi (warm) to 139 psi (cold)
3501 - 6400 rpm = 62 psi (warm) to 139 psi (cold)
Was the code you had oil pressure related? If so, is it still a current code?
There are some things related to oil viscosity, filter installation, correctness of the filter, that will set an oil pressure code.
. I guess I'm good. Thanks I had concern with leaking seals
Never below 35psi warm at idle
Your oil pressure seems to be right where it should be. The 3.6L engine has 3 oil pressure ranges based on rpm. 600 - 1200 rpm = 5 psi (warm) to 139 psi (cold) 1201 - 3500 rpm = 30 psi (warm) to 139 psi (cold) 3501 - 6400 rpm = 62 psi (warm) to 139 psi (cold) Was the code you had oil pressure related? If so, is it still a current code? There are some things related to oil viscosity, filter installation, correctness of the filter, that will set an oil pressure code.
Your Jeep came with an oil pressure gauge? Or are you saying that it has a pressure sender (not the idiot light switch the earlier models had), and that it is accessible only through menus? Curious, because something like Android Torque Pro might give folks an OP gauge if so.
