Programmer info
What's the original question and intent with a programmer? The Superchips units are nice if you know exactly what you're buying into and going from there. My original intent with the Superchips was to kill my TPMS, long before Jscan was ever a thing. It killed my light weigh suited me just fine. I then found that it could adjust for tire size. Well once you're into those things, you start poking around. I found the "tunes" and while they don't make a massive difference, I found (should say, "I feel/ think/ believe") applying a tune would take the delay out of the electronic throttle, with the exception of the fuel saver tune. That particular one seems to really delay the pedal.
So if you want to tune for HP or TQ- there might be better options out there. If you want to pull the delay out of the pedal, I like the Superchips. I've tried the pedal calibration a few times and it doesn't make the same adjustment that the Superchips did for me.
I guess I should wrap up with saying that I've run the Superchips for almost 10 years and I've only had the Jscan for a couple now. I bought a pack of licenses knowing that I surround myself with jeep folk. It does nice things that the Superchips can't touch but I've not found a throttle delay reduction in Jscan.
It will work with a whole bevy of vgate iCar OBDII scanners (search Amazon). Looks like they went up a little in cost as these things used to be $12-15. Still cheap with the $20 app license though. Worth it for the diagnostics alone. You definitely don't have to go high end like BlueDriver (I have one of these too and they are nice as a diagnostics tool that works with all vehicles).
Supported and Not Supported OBD Adapters ? JScan
thanks for the recommendation!
Cam
I have a SuperChips TD2, JScan, and HP Tuners. They all have their place. JScan is the cheapest and easiest, but limited "tuning" capability. HP Tuners is the most expensive and complex, but will do anything you want to do with it.
