Quadratec Winch Problem (2nd One)
Old Dec 5, 2012 | 12:58 PM
simadownow6988's Avatar
Default Quadratec Winch Problem (2nd One)
I bought a Quadratec winch for my Jeep a few months ago. It was one of their 9500# versions. After installation, I noticed that it wouldnt wind up without making a loud squeeling noise. I thought that maybe it was because it was new. A few weeks ago, I tried to use it and it acted like it was locked up. I had to wind it back up by rotating the drum with my hand in freespool.
After calling QT, they replaced my winch with another. Install again was a pain in the ass, but I finally got it. This winch only works sparaticly. I used it to put tension on a wire fence, and while pulling the fence line tight, it was cutting on and off (like 3 second bursts). The problem happened on and off all day. I checked the remote plug and it seems like its tight and making connection.
Before I call QT and ask for a replacement AGAIN, has anyone else had any problems with their QT winch? I dont want another if this keeps happening. Im tired of installing and removing winches.
Old Dec 5, 2012 | 01:56 PM
Gman*2007's Avatar
Thats ashame, it looks like a well made winch. I'm running the Smittybuilt that has mixed reviews but it works just fine for me.
Old Dec 5, 2012 | 02:37 PM
kfxbryan's Avatar
I would make sure you have a good ground connection.
Old Dec 5, 2012 | 05:18 PM
Checked the ground, the positive, the wires from the selenoid, and the plug. Everything is good and tight.
Old Dec 6, 2012 | 09:45 AM
I called QT today and talked to Dave. He was very cool and helpful.
He told me that the problem could be in the remote. I have a buddy that has a winch like mine (that works fine) that will let me borrow his remote to see if that helps. Ill keep you guys informed.
Old Dec 6, 2012 | 05:43 PM
red2010rubi's Avatar
Sorry to hear about the issues hope it's just the remote!
Old Dec 8, 2012 | 08:37 AM
Well, tried my buddys remote. Winch still cuts out sometimes. Ill give Dave a call Monday to see what we need to do.
Old Dec 8, 2012 | 09:14 AM
AFGuardianAngel's Avatar
Good Luck. A winch will be one of my next purchases so I'll definitely keep this in mind..
Old Dec 8, 2012 | 09:19 AM
samcarlos's Avatar
Try new smittybilt x2o 8000. I highly recommend it and its plenty for a jeep! Easy install
Old Dec 8, 2012 | 04:32 PM
Malan35's Avatar
I would definitely check the ground. If necessary, run it straight to the battery to confirm a solid. ground. I was having same problem with my smittybilt
