Rear diff flush
Old Dec 25, 2013 | 04:09 PM
JKFIRE894's Avatar
Default Rear diff flush
Flushing out my rear diff fluid and wondering if I need to replace the seal with a new one or just new silicone? It's for an 08 Sarah
JKFIRE894's Avatar
Saraha unlim.
Old Dec 25, 2013 | 04:17 PM
Maertz's Avatar
what seal are you talking? just drain via the drain plug and refill with the top fill plug? If your taking the dif cover off, yes you will need to re-rtv or use a lube locker.
Old Dec 25, 2013 | 04:19 PM
blue project's Avatar
If your removing your diff cover you will need new rtv or a lube locker. Does the cover need to be removed, no. It it was me I would just drain through the plug.
Old Dec 25, 2013 | 04:21 PM
JKFIRE894's Avatar
Nice I was under the belief you needed to take it off, spray down with some brake cleaner and then bolt back on and fill it up.
Old Dec 25, 2013 | 04:23 PM
Maertz's Avatar
i wouldnt do that unless your doing the dif fluid after a gear install. but it wouldnt hurt if you want to.
