Rear-ended
My jeep was involved in a hit and run last friday. The punk clipped my rear bumper. I was shocked to find no damage to the body. Bumper is trashed (gave me a reason for a new one), my flair is hanging and my license plate bracket is trashed. I don't think he hit the tire, but I feel that I'm bouncing around a bit more, maybe it is my imagination. Everything looks intact, any suggestions on what to look for. I have a RC 2.5 BB with shocks and 33's KM2
Can't say for sure cause there's no Pic's but from personal experience found out that there's a whole lotta nuthin between the plastic and the steel under it. Maybe you'll find you can drill a couple pin hole's and pull the plastic back out.
It could have done more than you think. It should go in to a competent body shop for a full check out. If it was hit hard enough on a corner, the frame could actually be damaged. It's not too hard to do, either. The condition is called a "diamond" because it would actually push one frame rail in front of the other and make a parrallelogram out of your frame, instead of a rectangle that it normally is. This can cause all kinda driving maladies. I would get it looked at soon.
