rotating tires question.
Old Jun 18, 2016 | 12:48 PM
tribulation138's Avatar
Default rotating tires question.
I rotate my tires front to back twice a year.
Bfg 33s up front and definity Dakota 33s in rear. But for the life of me can't understand why my traction control light comes on only with the Dakota's up front. I have to keep under 30mph on right hand curves or it will blink.
Never comes on with BFGs up front?
Any theories?
Speedometer and and alignment is all good.
Old Jun 18, 2016 | 03:10 PM
14Sport's Avatar
I've read that not correcting tire size in the computer can cause the light to come on during sweeping right turns like highway off ramps. Do you cross rotate as well as front to back? It sounds like the Dakotas are larger making it more sensitive or unevenly worn. But that's just me speculating.
Old Jun 18, 2016 | 03:38 PM
can't believe the computer would be that sensitive
Old Jun 18, 2016 | 03:40 PM
Maertz's Avatar
Agreed if there not damn near identical sizes to start if can for sure mess with it. Itl show different speeds at each wheel
Old Jun 18, 2016 | 04:35 PM
14Sport's Avatar
I can't say for sure. It's just something I read that made sense to me. And on more than one occasion.
Old Jun 19, 2016 | 04:45 AM
zstairlessone's Avatar
Measure the diameter of all 4 tires to see how far off they are in size. The wheel speed sensors/control module are sensitive enough that small differences in size will cause the traction control to think the wheel is spinning. When you make a turn the two front tires are already rotating at different speeds so any difference side to side or to the rears will be magnified.
Old Jun 20, 2016 | 04:14 AM
Ya. My bfg fronts are a 1/2 inch bigger than than the dakota rears.
Old Jun 20, 2016 | 08:21 AM
mr72's Avatar
There is the problem. The ECU is detecting a difference in speed between front and rear axles and interprets that as a loss of traction.
You should run all four identical brand/model/size tires.
Old Jun 20, 2016 | 09:35 AM
jedg's Avatar
Vet Army
Or, for a temporary solution, change the air pressure in one set so that the diameter of that set matches the diameter of the second set.
Old Jun 20, 2016 | 09:45 AM
mr72's Avatar
Changing the tire pressure of a radial tire will not change the diameter of the tire. And actually it's the circumference that matters, and in order to change that, you have to remove tire material.
