Rubicon vs. Sahara
Old Jan 11, 2011 | 08:18 PM
OnBelay's Avatar
Originally Posted by Mskh20
My Rubi JKU forgives you this one time for implying she isn't a real trail rig. She can be testy though, so she may not be so forgiving the next time.
IMHO, it really depends on what you want to wheel, where you want your rig build to end up and how long it you think it will take you to save the funds to get there. I love my Rubi and bought it knowing I'd probably never be running 37's with ARB lockers and $3k in axles. I'll get a mild spring lift, 35's, bumpers and winches (front and rear), dual batteries, a snorkel and a sport cage and basically call it done. For ME, the Rubi fit the bill perfectly and it performs better than any vehicle I have ever driven off road (in no small part due to the factory lockers.) If you are planning a major build with 37" or larger tires, then I agree with Dawn that getting an X probably makes more sense.
^^ what he said.
Sorry, getting tired and lazy here - been on the forum all night long. Making up for time away.
@ the OP: decide what you want, what you're doing to do with it, how much money you want to spend, and what your time frame is for modifying it. Those will be a big factor in your decision(s).
Bowing out of this thread so the experts can chime in!
Old Jan 11, 2011 | 08:22 PM
Sharkey's Avatar
Originally Posted by jeeplease!
I'll probably stick with my 35's... The 7's do look sick though! I hunt a lot and live in a rural area so I definitely have use for off road compatibility, but on the other hand, my 23 mile drive to school is a killer for gas. The main things I've seen for improved mpg's/performance are either chips or gears? Which one? if not both?
Gears then chip. Then again, if you buy an X, you might be looking at a new front axle down the road, even with 35's. The Rubi Dana 44 should do a much better job handling 35's than the X's Dana 30 (at least I think it's a 30)...and the never ending list of "if you do this you should do that" begins.
Old Jan 11, 2011 | 08:28 PM
Sharkey's Avatar
Originally Posted by OnBelay
^^ what he said.
Dawn's advice is good advice, and I for one am certainly no expert on anything related to Jeeps. The real point is that we all have different ideas in our heads about what we want and why we want it. You (the op) need to make some of those decisions for yourself to ensure YOU get what YOU want. It may be a Rubi with light mods, it may be a Sahara with 10k in mods...it doesn't really matter so long as it is what you want.
jeeplease!'s Avatar
Well I'm running a sahara with 35's, price wise what would gears be compared to programming? And would gears tear up my rig in the long term? I've kind of gotten that notion.
Old Jan 11, 2011 | 08:43 PM
Sharkey's Avatar
I think you can expect gears to run you between about $1k and maybe $1200 including labor depending on who does the install. I don't remember the going rate on a Superchips Flaspaq but I imagine it's about $350 or so (no labor cost for install). With the gears (actually with the bigger tires as well), you need at least some sort of programmer to correct your speedo. You can do it cheaper than the Flaspaq, but it has some extra features that most people seem to feel are worth the extra price.
As far as new gears tearing up your rig, I'm not sure why that would happen. If anything, I would thing the more appropriately matched gears (to tires) would create less wear on your rig because your engine doesn't have to work as hard to get the bigger tires moving. I'm sure someone else can offer a better (more technical) explanation though.
Old Jan 11, 2011 | 08:47 PM
jeeplease!'s Avatar
Sounds like the flashpaq is a definite buy with or without gears then?
Old Jan 11, 2011 | 09:10 PM
Sharkey's Avatar
There are a lot of threads on the Flaspaq. It's not going to give you the performance benefit that gears do, but it might help if you aren't ready to get gears. Spend some time searching around the forum and reading the various threads that are on topic. You need to formulate your own opinion based on a lot more opinions than just mine. Reading what everyone has to say is part of the fun of the forum.
Old Jan 11, 2011 | 10:02 PM
kiwi's Avatar
Get a JK diesel and you"ll have the power without any Rubicon gear requirements.
Sorry that's right you cannot buy a diesel
Old Jan 12, 2011 | 08:54 AM
JK Mikey's Avatar
The biggest differences that will cost you $$ later between the two are:
1- Sahara D30 front axle, Rubi D44
2- Rubi has better transfer case for wheeling
3-Rubi has E-(push button lockers F/R) Sahara has none..Some have Limited slip rear.
4-Rubi has better factory shocks and springs
5-Rubi comes with the BFGs At 33, Sahara Bridgestone AT 32 with 18" wheels.
Now depending on what you plan on doing with it. Should dictate what you should by. If you plan on doing a lot of hardcore wheeling. Buying an X with the S package would be the route I would go if I had to do it all over again. Then I would take all the saved money and build it up.
If your not going to wheel too hard then maybe getting a Rubi, and adding BB, and bigger tires and DS should be more then enough.
Old Jan 12, 2011 | 08:59 AM
Verdulken's Avatar
Well said
