Slipping in gears what can it be??
Old Jun 3, 2012 | 05:21 PM
cbenitah's Avatar
Default Slipping in gears what can it be??
I am on my way from SF to LA and I need a quick answer (hopefully)
When I start off 7/10 times the engine revs up to 3k and nothing happens. This is while being in Drive. (automatic)
At 3k it "catches" and it throws me forward.
Also happens at certain speeds on the Highway and I also sometimes feel a loss in power.
It did not do this yesterday so it's something new.
Anyone ? anything?
Old Jun 3, 2012 | 05:24 PM
cbenitah's Avatar
I should add to the question, is it still safe to drive it home, 340 miles to go. Rather not get stranded on 5 south
Old Jun 3, 2012 | 05:29 PM
ronjenx's Avatar
Have you checked the transmission fluid level? (engine idling; transmission warmed up; move selector through all the gears, ending in park or neutral)
Old Jun 3, 2012 | 05:31 PM
cbenitah's Avatar
Just did this and I'm not sure where I can see the reading? On the dash? Sorry but I love driving my jeep and let others do the working on it.
Old Jun 3, 2012 | 05:44 PM
cbenitah's Avatar
I just got a check engine light. I moved away from the result to quick and now it won't shoe again.
Might have said P0707
Old Jun 3, 2012 | 06:00 PM
kaptkrappy's Avatar
The auto trans has a fluid level dip stick under the hood just like the engine has a oil level dip stick. It has markings on it that will let you know if it's low or not. I'm betting it is.
Old Jun 3, 2012 | 06:08 PM
cbenitah's Avatar
Almost empty. Thanks!!!
Old Jun 3, 2012 | 06:14 PM
Zombie Hunter's Avatar
Only use ATF +4
Old Jun 3, 2012 | 06:15 PM
cbenitah's Avatar
Originally Posted by Zombie Hunter
Only use ATF +4
Ok good to know. I bought ATF -3 as that's all they had thinking there was only one kind.
Where do I add it once I have it? Can't find the cap in the engine bay
Old Jun 3, 2012 | 06:25 PM
kaptkrappy's Avatar
You have to use a small funnel and pour it (slowly) right down the dip stick tube.
