Smittybilt XRC 8 winch clutch question.
Old May 19, 2012 | 06:37 PM
fstopme's Avatar
Default Smittybilt XRC 8 winch clutch question.
Can somebody let me know if their Smittybilt XRC 8 winch clutch lever sticks or engages smoothly when operating it? I installed the winch then never had a chance to really use it because of my schedule and then two months passed and I can't remember how it felt out of the box. Thanks!
Old May 19, 2012 | 08:26 PM
7ESTES's Avatar
It's going to be a little tight the first couple times u use it. Mine is too but just has to be "broke in"
Old May 19, 2012 | 08:36 PM
fstopme's Avatar
Thanks! Much appreciated!
Old May 21, 2012 | 09:12 PM
Poser's Avatar
I've read the XRC8 doesn't go to spool position sometimes -mine did it too- and it seems a drop of oil on the shaft (where it enters the casing) fixes that. I'll just do it once in a while from now on...
Old May 21, 2012 | 09:14 PM
Slob's Avatar
I have found that slowly pulling a couple extra inches while pulling clutch helps some times. But ype kind of stiff for me, Only used twice thou
Old Jun 23, 2012 | 07:29 AM
Firelyle's Avatar
I try to keep mine covered as much as possible and since doing that the clutch seems to work much smoother. Less road crap getting in I guess.
Old Jul 7, 2012 | 10:22 AM
Raz70's Avatar
There is a cheap bearing with a spring to lock the engagement arm in place.It gets water and junk in it easy.You need to oil it up and it will engage easy.
Old Jul 8, 2012 | 02:32 PM
amarillojeepguy's Avatar
Default smitty winch...
the problem is its a smitty winch...never compromise quality for price!!!!! go get you a warn and live happy and stress free.. also dont get the vr series.....
Old Jul 8, 2012 | 07:08 PM
joshclark0331's Avatar
There is nothing wrong with Smittybilt winches. Warn winches have issues every once in a while as well.
